Wow cowboy, are you feeling ok? Calling the girl a fat b...
Shit man you gotta relax. Maybe you should go get laid instead of spending all you're efforts bagging people out and been a out right dick, maybe that's why you're cranky?
Every time a girl approaches you they sense you're negativity and hostility, and say f&$@ that.
Unlucky.
Oh and it was it English. Maybe you need glasses or is my puny sentence too much for you too comprehend?
Haha, stirring and stirring. :).
Mate, I'm perfectly relaxed. If you think this is any effort, then you're mistaken.
I'm about the most positive person you could imagine, I just don't suffer idiots. Never have, never will.
So you've delved to the "measuring self-worth" depths now, I see. Sorry, won't be going there.
  • Replies 196
Posted Images
I can tell you now, I do not believe for one second that you ride. Also, you might want to Google "Define: hypocrite" because you clearly do not know what it means. There's nothing hypocritical about anything I've said.
Yes there are plenty of idiots on bikes. Difference being, if they f**k up generally they are the only ones who will have
to deal with the ramifications.
For even a milli second i dont give a f**k if u dont believe im a rider and if i was to google the definition of being hypocritical...why dont you try to read or watch the news or maybe GOOGLE!!!....who is the biggest donors in the road right now i know that cuz im a nurse and almost everyday iv seen enough to make me not ride my motorbike everyday fair enough if thats the risk u want to take but dont come around here saying riding is a dangerous as driving....try to think it again most cars these days has airbags and compairing 4 wheels to a 2 wheels is definitely and more likely to survive in a crash than a motorbike!!!...commom sense!
I also don't believe that you are a nurse. Nurses need tertiary education which means they can spell and construct a sentence beyond that expected of a 10 year old. You're insulting nurses everywhere by trying to make us believe that someone of your obvious supreme intellect would be a nurse.
Edited by Cowboy1600
Unlucky.
+ 10
Hahaha agreed cranky old man!!!!
Wow positive? By what you were saying If thats positive then what is negative??
If thats all u can say then i feel sorry for you by being sooo lame! Im on my break right now and using my iphone so im sorry if my thumb is a bit bigger so touch fones can be challenging at times so maybe u really need an eyeglass to read properly u cra ky old man!...:)
Telling it how it is isn't by definition negative.
Not receiving the back slapping you expected doesn't relate to negativity.
And quite frankly, like I could give a f**k if you perceive my comments to be negative.
Call them whatever you will, doesn't make the fact that your friend was being an idiot and deserved to get booked any different.
Don't feel sorry for me. There's simply no need.
And I have an HTC Desire, and big hands, yet am capable of posting on forums without looking like I struggled to graduate from primary school. Hell, I can even do it when pulled off the side of the road and still have my motor bike gloves on. It's not hard, really.
K then MR GOOD CITIZEN!!!
minus 10 ...:))
Dont lie abt it...thats the worst
U can barely read henceforth foing that is not possible!!!...:)
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
