1) so unintentionally is assumed
2) How do you know bitch wasn't the watching road? That is an assumption!
3) I am impressed you don't have a gold honda badge stuck to your A**
4) Speculating she was using both hands, and the basis of your point to flame someone on a hunch
My point for talking shit to you is it isn't very nice when you don't know all the facts, and bitting everytime is so just making him feel like the bigger man. Cowboy breath and let it go.
I agree it is stupid to drive and do anything else. both hands should remain on the wheel. But bring into question these activities that can distract a driver
1. Naked girl
2. Girlfriend going down on you while driving
3. talking on the phone via hands free
4. screaming kids in car
5. Sub woofa reverb moving all car glass for no vision
6. Having 1 F**Kin head light and using high beams and being blinded
and the list can go on......
I fixed the typo, it was meant to say intentionally or unintentionally. ie. never.
Fair assumption IF SHE WAS BOOKED FOR IT.
Takes more than a cheeseburger to outsmart me.
Regardless, the copper felt it necessary to book her so she was obviously not in control of her vehicle.
Don't disagree with any of your last point/s :D
  • Replies 196
Posted Images
You guys are like Energiser Bunnies.
Surprised it is still going
Meh, good way to waste a bit of time waiting for the bell to ring.
In fact, it's time! Friday arvo means Friday drinkies. Better go have my single stubbie. Wouldn't want to go over 0.05BAC and possibly hurt someone on the way home!
Night all!
I knew I knew OP from somewhere
http://www.skylinesa...d-answers-guys/
Oh man, I feel like I've just been RickRolled.
Time to go write my lines:
Must stop arguing with children.
Must stop arguing with children.....
Bitch got booked, bitch deserved it. Perhaps I was unjust calling her fat. I take that back.
You're cut because you didn't get the sympathetic circle jerk you were expecting.
And again, I'm not defending the po-po here. Many of them are total dream boats. But I've also seen the number of complete no hopers plaguing the streets of which, I'm afraid, your friend sound like one of. Sorry, but it's unlikely she would have been booked for eatign while driving unless it was obvious she wasn't paying attention to what she was doing. Sit behind a car begin driven by someone distracted by something and you can pick it quite easily.
First of all i feel sorry for your wife!!!... If u can call someone u dont know a bitch how much more someone u see everyday!!
Secondly almost evry1 agrees that there is heaps of f**ktwits police out there than a decent one!!!
Thirdly my friend which u called a bitch was doing 40ks on a 50k zone its not like she was driving wrecklessly and doing a 120 on a 50 zone and was stopped as stupid cop lady thought she was holding a fone while driving thats what the cop lady said and check every single detail of the car until she could not find anything wrong so book her 120 anyway For eating a cheeseburger when it was all gone by the time cop finished checking the car!
And lastly i could not care less what you think until u started calling names...u started it so il finished it!!!
1. Naked girl
+ 10
Lmao
Guest
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
