i cant seem to find a thread listing places that are good so where does every one get their mild, stainless , alloy etc pipes from?
something like:
company name
contact details
address
what do they stock( pipe , sheet etc )
see if we can get the 1st post edited by a mod and group them by state
also where can i get a mild steel donut's?
Edited by Dan_J
https://www.sau.com.au/forums/topic/381400-fabrication-supplies/
great useful links guys :thumbsup:
ebay link is good, i only found their sister store kj trucks before hand
sent off a quote request for spareco and good to know their in VIC :)
keep the details coming, chat minimal and we may get a sticky to help the others out :cheers:
Depends how much of the raw material your looking to buy as to the best place to buy it.
For the DIY person you need to find a fabrication shop and buy their off cuts, then ask if they can buy in things like dounuts and longer tube lengths for you.
I do it for heaps of people who do minor stuff themselves.
The back of my guillotine is overflowing with decent sized off cuts that people drop in and pilfer scoring themselves a bargain.
The price you'd pay retail for a 1000x1000mm sheet of 3mm alloy I can buy 2 sheets of 2400x1200 so i let small sections go for bugger all.
There is also JNT performance in Wollongong. Steve is great to deal with and I know alot of fabricators who buy spun alloy products from him.
Also does dounuts, AN fittings and short sections of tube.
I pilfer the shops like what Risking mentioned. I go to a place called marindi fabrication, local stainless fabricator, is awesome to deal with and sometimes throws in pieces for next to nothing
It's the cheapest way when you only need a small section of sheet or tube etc.
I always get guys bringing in cardboard templates. They find some offcut ( which always has PVC covering so it's not scratched or anything) that is big enough for what they want and away they go.
Same for tube.
  • 1 year later...
  • 2 months later...
Can anyone recommend a shop in Melbourne to pick up some off cuts of stainless tube? Even mild steel. Also some plate/bar.. just some odds and ends really.
Cheers.
Check your local fab workshop or even a balustrading fabricator; they always have offcuts.
Offer them a sixpack of their favourite beverage; you'd be surprised.
I don't live in Melbourne yet (moving there soon) so don't have any idea about Fabrication shops down there really. I had some work done by Jake at JDI Fabrication in Bayswater, but he didn't seem to have much in the way of offcuts/scrap hanging around unfortunately.
  • 1 month later...
  • 4 weeks later...
I live in Wollongong so jnt is nice and close
as for other alloy stuff like sheets angles thick wall pipe ect i go to another local place called allyman they have piles of off cuts that you pay next to nothing for I always end up getting heaps more then I need
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
