hey guys just put some NGK R5671A-8 spark plugs in that my mate recommended me to use & now my ecu hand controller is spazzing out coming up with all weird readings on it. it also was blowing some smoke with black liquid out.
why would this be?
engine is an rb25/30det conversion with gt3076r, aftermarket ecu bla bla bla
any help would be great
cheers luke
https://www.sau.com.au/forums/topic/381446-spark-plug-help-rb2530det/
Nope everything runs fine, just cant read eveything on the ecu due to everything going weird. & blowing some smoke out the exhaust!
I put my old plugs back in & the issue isn't happening now. The ecu wouldn't need tuning for these plugs would it?
just looked up the part number on those plugs. they are a non resistor type plug, so they may be interfering with the ecu.
taken from the ngk website
Resistor type spark plug’s incorporate an internal resistor to suppress ignition noise generated during sparking. The ignition noise which is often known as either electromagnetic interference (EMI) or radio frequency interference (RFI) can disrupt electronic communication signals, effecting the performance of sound systems, cellular phones, two-way radios and even engine management systems.
As EMI or RFI can also cause premature failure to other electronic components in a modern vehicle, it is important that resistor spark plugs are used to prevent this possibility.
Put simply, when a spark is formed it creates a mini-earthquake in the electronic world; the internal resistor in a spark plug filters out the noise created that may affect electrical components.
long story short, if it all works fine with your old plugs, just get some new ones of them if you want new plugs.
hmm yeah that makes sense now. they worked fine in my mates rb25 maybe because his is series 1 & mines series 2?
i was told the ones i had are crap due to my engine chewing through plugs every 2000ks witch is very expensive in the long run.... cheers for the info mate
anyone recommend any good plugs to use other then these??? lol
cheers
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
