hey guys just put some NGK R5671A-8 spark plugs in that my mate recommended me to use & now my ecu hand controller is spazzing out coming up with all weird readings on it. it also was blowing some smoke with black liquid out.
why would this be?
engine is an rb25/30det conversion with gt3076r, aftermarket ecu bla bla bla
any help would be great
cheers luke
https://www.sau.com.au/forums/topic/381446-spark-plug-help-rb2530det/
Nope everything runs fine, just cant read eveything on the ecu due to everything going weird. & blowing some smoke out the exhaust!
I put my old plugs back in & the issue isn't happening now. The ecu wouldn't need tuning for these plugs would it?
just looked up the part number on those plugs. they are a non resistor type plug, so they may be interfering with the ecu.
taken from the ngk website
Resistor type spark plug’s incorporate an internal resistor to suppress ignition noise generated during sparking. The ignition noise which is often known as either electromagnetic interference (EMI) or radio frequency interference (RFI) can disrupt electronic communication signals, effecting the performance of sound systems, cellular phones, two-way radios and even engine management systems.
As EMI or RFI can also cause premature failure to other electronic components in a modern vehicle, it is important that resistor spark plugs are used to prevent this possibility.
Put simply, when a spark is formed it creates a mini-earthquake in the electronic world; the internal resistor in a spark plug filters out the noise created that may affect electrical components.
long story short, if it all works fine with your old plugs, just get some new ones of them if you want new plugs.
hmm yeah that makes sense now. they worked fine in my mates rb25 maybe because his is series 1 & mines series 2?
i was told the ones i had are crap due to my engine chewing through plugs every 2000ks witch is very expensive in the long run.... cheers for the info mate
anyone recommend any good plugs to use other then these??? lol
cheers
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
