hey all,
im putting this up for sale/eoi as i think its time to move on from the car scene and start a future.
i have had this car for 6 years where it started out as a stock rb20det r32.
the car has its original plates and can be regod!!!!
mods.
CAR:
1993 r32 type m
sunroof (working)
ENGINE:
s2 RB25, RB25 gearbox with excedy heavy duty brass button clutch
Mahle forged pistons
spool rods
crank was balanced, grub screwed
block decked, honed, acid dipped
block grout filled
nitto oil pump
ross metal jacket balancer
n1 water pump
oil restricters
head to sump oil drain
refreshed head
gtr valve springs
tomei pon cams
r34 neo CAS
r32 gtr rocker covers/timing cover
mines cam cover baffles
working vct
gates timing belt
3inch turbo back exhaust with rear oval muffler
Garrett GT3076 a/r .60 exh .82 surge slotted and external gate full speedflow fittings and braided line (100kms)
craig helps stempipe manifold with 50mm synapse watsegate (100kms)
plazmaman intake plenum (100kms)
id1000cc injectors top feed with all speedflow fittings (Dyno time only)
aeromotive FPR
e85 fuel filter
moroso vented catch can with speedflow fittings
ase oil cooler with relocation and speedflow fittings
battery relocated to the boot
surge tank, gtr lift pump, bosch o44 external with speedflow fittings
have a r33 powersteering pump and reservior not yet fitted to completely remove hicas
ELECTRONICS:
Power fc with hand controller
eboost 1
defi bf water temp, oil temp, oil pressure with control unit
hks boost guage
cd player, rear 6x9's and front splits
DRIVELINE:
cusco 2way 4.11 diff
r34 gtt front brakes with dba4000 slotted rotors
front caster arms
rear camber arms
BRAND NEW bc gold coilovers (not yet drive on)
hicas lock bar
WHEELS:
18x9 -6 vskf 225/40 neutons
18x10.5 vskf 235/40 neutons
BODY:
GENUINE gtr front bar with N1 vents and lip
GENUINE gtr alloy front guards
GENUINE gtr corner indicators
dmax style CF bonnet
Mspec side skirts
mpsec rear pods
VIVA rear 25mm bolt on guards
vanquish roof spoiler
s13 origin boot lip
painted in AH3 paint (matte) not perfect but nice enough
INTERIOR:
bride style fixed back
takata style harness
stock front seat
no rear seats
deep corn wheel with boss kit
OVERALL:
engine was built by redRracing in sydney who have built MANY tough cars (twoogle, nitto etc)
engine has done no more than 2000kms most dyno time
car made before 1000cc injectors 380kw on hub dyno on e85 before pfc was put in running vct
car is now at horse power in a box waiting for a new tune with the pfc and 1000cc injectors, stiffer gate spring and 25 psi.
this car is a turn the key and drive car, no money to spend (well a cage)
i have done all the hard work and $$$$$ spending so my loss is your gain..
will be sad to see it go but i just dont use the car enough and it would be better suited to someone who would.
ok so serious business!
if you think its too much stay out, if you dont like it stay out.
if it sells it sells, if it doesnt meh ill leave it there.
PRICE:
16k! pretty firm as im not in a rush to sell.
PICS:
seen here... http://nissansilvia.com/forums/index.php?showtopic=512613
https://www.sau.com.au/forums/topic/381452-1993-r32-gtst-full-of-fruit/
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
