hey all,
im putting this up for sale/eoi as i think its time to move on from the car scene and start a future.
i have had this car for 6 years where it started out as a stock rb20det r32.
the car has its original plates and can be regod!!!!
mods.
CAR:
1993 r32 type m
sunroof (working)
ENGINE:
s2 RB25, RB25 gearbox with excedy heavy duty brass button clutch
Mahle forged pistons
spool rods
crank was balanced, grub screwed
block decked, honed, acid dipped
block grout filled
nitto oil pump
ross metal jacket balancer
n1 water pump
oil restricters
head to sump oil drain
refreshed head
gtr valve springs
tomei pon cams
r34 neo CAS
r32 gtr rocker covers/timing cover
mines cam cover baffles
working vct
gates timing belt
3inch turbo back exhaust with rear oval muffler
Garrett GT3076 a/r .60 exh .82 surge slotted and external gate full speedflow fittings and braided line (100kms)
craig helps stempipe manifold with 50mm synapse watsegate (100kms)
plazmaman intake plenum (100kms)
id1000cc injectors top feed with all speedflow fittings (Dyno time only)
aeromotive FPR
e85 fuel filter
moroso vented catch can with speedflow fittings
ase oil cooler with relocation and speedflow fittings
battery relocated to the boot
surge tank, gtr lift pump, bosch o44 external with speedflow fittings
have a r33 powersteering pump and reservior not yet fitted to completely remove hicas
ELECTRONICS:
Power fc with hand controller
eboost 1
defi bf water temp, oil temp, oil pressure with control unit
hks boost guage
cd player, rear 6x9's and front splits
DRIVELINE:
cusco 2way 4.11 diff
r34 gtt front brakes with dba4000 slotted rotors
front caster arms
rear camber arms
BRAND NEW bc gold coilovers (not yet drive on)
hicas lock bar
WHEELS:
18x9 -6 vskf 225/40 neutons
18x10.5 vskf 235/40 neutons
BODY:
GENUINE gtr front bar with N1 vents and lip
GENUINE gtr alloy front guards
GENUINE gtr corner indicators
dmax style CF bonnet
Mspec side skirts
mpsec rear pods
VIVA rear 25mm bolt on guards
vanquish roof spoiler
s13 origin boot lip
painted in AH3 paint (matte) not perfect but nice enough
INTERIOR:
bride style fixed back
takata style harness
stock front seat
no rear seats
deep corn wheel with boss kit
OVERALL:
engine was built by redRracing in sydney who have built MANY tough cars (twoogle, nitto etc)
engine has done no more than 2000kms most dyno time
car made before 1000cc injectors 380kw on hub dyno on e85 before pfc was put in running vct
car is now at horse power in a box waiting for a new tune with the pfc and 1000cc injectors, stiffer gate spring and 25 psi.
this car is a turn the key and drive car, no money to spend (well a cage)
i have done all the hard work and $$$$$ spending so my loss is your gain..
will be sad to see it go but i just dont use the car enough and it would be better suited to someone who would.
ok so serious business!
if you think its too much stay out, if you dont like it stay out.
if it sells it sells, if it doesnt meh ill leave it there.
PRICE:
16k! pretty firm as im not in a rush to sell.
PICS:
seen here... http://nissansilvia.com/forums/index.php?showtopic=512613
https://www.sau.com.au/forums/topic/381452-1993-r32-gtst-full-of-fruit/
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
