hi all,
recently bought the car. it has a drift iridium (digital) boost gauge. ad idle its reading -18psi. is that a normal/correct reading, or is the gauge malfunctioning. for some reason i think it should be reading less.
the car is pretty much bone stock mechanically save for a CAI, exhaust, intercooler, boost controller (running stock boost level).
forgive me for my ignorance, its my first r33.
thanks
https://www.sau.com.au/forums/topic/381472-r33-gts-t-vacuum-at-idle/
Yep Psi is a measure of positive pressure
And negative pressure. Pressure units are quite universal. It's just that manifold vacuum is traditionally read in some of the more bullshit units like inches or mm of mercury. It shits me to tears that whilst we have a perfectly good set of self consistent SI units for pressure (Pa, dPa, hPa, kPa, MPa) that people continue to talk in rubbishy units based on the column height of some randomly selected fluid like mercury or water. It's time to come kicking and screaming into the 20th century is what I say.
Isnt it because Mercury isnt affected by air density as much?
Therefore measuring head flow in mmHg or inHg is more consistant, rather than saying x port flows y cfm at 22.14646363 deg C and 1009 QNH.
I think...lol
I've seen mercury and water used, there is a reason i just dontt remember
A negative psi value does really exist. you can't have below 0psi in a vessel. 0 pounds/square inch
Remembering that 0psi on your boost gauge is still 1atmosphere
Yeah you can. Absolutely no reason why you cannot express it in psi. The positive pressure is outside the vessel.
psi is a measure of force (pounds force) per unit area (square inch). So is any SI unit. The Pascal (Pa) is defined to be one Newton (force) per square metre.
same same. Just that SI units don't suck because they are easily convertible from one to another without having to use/remember arbitrary conversion factors. And the mmHg and mmH2O units require that you use the force of gravity to convert them (9.807 m/s2) which is gay, and is not universal because the same real pressure would give you a different fluid column height on a different planet (or even a different height on different parts of Earth where the force of gravity is slightly different from elsewhere. It is a very small difference though!)
cheers
Makes no difference whether you're talking absolute or gauge pressure. It's all pressure. If you totally evacuate a volume you have zero absolute pressure in it. That's zero psi, zero kPa, etc etc. The gauge pressure (relative to 1 atm pressure outside the vessel) inside is -1 atm, -14.7 psi, -101.325kPa (assuming we're at sea level of course). Let a little bit of air in there, and you might have a pressure of 1 psi absolute, -13.7 psi gauge.
cheers
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
