Ive been having a a fair look at turbo-ing my car recently and all the ways in which to do it. And then I thought along the lines of a new car and thought id get peoples opinions on whether its best to Start with a turbd skyline or get a rolling shell and build it up? Id eventually be looking to replace most stock parts with slightly better options because i'd like to be fast but not become a track demon or anything.
What are peoples thoughts on it? also would be good to get a perspective through cost and then if cost wasn't an issue?
Cheers!
https://www.sau.com.au/forums/topic/381476-better-to-buy-or-build-up/
Depending on what you buy......a good r33 GTR with say 350kw goes for $30-40K. If you did that yourself you could spend close to that on just the mods alone. The car will still set you back +$20-25K. And its relative, so any car will be similar give or take.
The only thing you miss out on is the learning experience and the 'built not bought' edict. But you'll have a lot of skun knuckles, late nights and downtime achieving it.
Well ideally im not looking for a GTR i just want something like a 97 or 98 R33. If i bought It I just want it to be turbo with reasonable k's but i figure build it is buy a beater and replace its engine etc
Ok, then expect to pay $15-$20K for a good one [you can get cheaper, but I did say a good one]. I have a '98 and I gave up keeping a running total at $20K. And I noted everything down, if it was for the 'line then I added it to the total.
Honestly there are absolute sub $20K 300rwkw bargains out there in the Gtst range, and in very good to pristine condition - but take your time and shop around, its a buyers market.
I suggest buying one with most things donethen adding your own touch I wish I did that now. I bought my 32 for 3 k and now spent 6 on it and I havent even touched suspension yet unless your like me and want to be able to say I built this car myself then spend the money on a mostly done one
Buying a modified car is the cost effective way to do it. You can save many thousands of dollars that way (save $10 to $15K or more).
The key is patience. Keep an eye on the forums - find a really good car with not too many miles on the new engine.
If you want ot personalise it or money is burning a hole in your pocket there is always more you can do!
Buy one already done, then spend a few k getting it up to your standard, that way it is the way you want it and it didn't cost a bucket. If you buy one and mod it yourself it is such a money pit.
The other option is to buy a defected car or a GTR with a blown motor and do the engine swap yourself, this way you save massively on the buy price however you have to be capable of doing the work yourself.
yeah one already done will have half the bits you will want already on it..
So even if you do have to rebuild it at least it had lots of good parts already..
I now have a pile of stock parts in he shed that are good for nothing and a 20+k bill, I have seen cars with as much or more power selling for half that..I would probably be lucky to sell it for 10k and even then it has to clear a RWC somehow somehwere
See the big problem can be getting them transferred into your name if the car has alot of modifications..But if you know the right people and have access to borrowed parts for a RWC you can get around this, meaning you could buy something even cheaper because the previous owner couldn't bother to clear a defect or RWC..
my mate got a pretty good deal
r33 s1
forged motor + hks 2530 (i think) and all the supporting fruit ~ 280-300 rwkw (i forget now)
+ suspension stuff sorted too
$7k
only downside is it had peeling clear coat
hunt around and make the decision on whats available to you, if there aren't any decent ones about then you might have to build your own
Look around, then decide....
The build that I wanted, I havnt really seen done.
so, I'm building my own.
I also didn't have the money to spend on a moded one when I first got my car 5 years ago.
Definitly would have saved money buying a car that was already done.
If you've got the money, I recommended buying as close as you can get to what you want.
If you're chasing something that's a bit left field, build it yourself.
Either way you decide, goodluck with the new car.
And post pics when you get it :)
^^This.
    • Nah, you failed to pay your washer cover subscription and BMW have revoked your access.
    • Haha thanks Lith,  So it's currently working quite well and the torque reduction is setup and working phenomenal. It also got a custom torque convertor from All Fast in WA. Stall speed somewhere around 5500rpm unlocked but still with the lockup. The car went back onto the dyno after a 3yr hiatus (even with the dbw, and other mods completed in this time) managed to make ~515kw at all 4 hubs. Sean setup the Torque reduction which now sounds awesome and working well. We setup adjustable torque controlled launch control aswell.  Man what a feature. Especially when drag racing on street tyres I Managed to get out to the drags late last year and tick a huge bucket list item off of running mine and the cars first 9. Car went a 9.98 @142 Still had the young fellas car seat in the back aswell.  This was on 255/40/17 Nankang AR-1.  Currently the Turbolamik is still completing it's own torque calcs and managing shift times from there. Unfortunately emtrons can export is still a little restrictive to export the ecu calculated torque just yet but I have recently been suggested a work around that I just haven't had a chance to trial yet.
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
