So was rigging up a vacuum line to do the ol' skool steam cleaning of the engine....pulled off the boost controller hose that's connected to the bung on the std intercooler return pipe (connects to crossover pipe) and instead of it pulling air in at idle, it's pushing air out? So it's under pressure instead of under vacuum? How can that possibly be, shouldn't intake be under vacuum at idle?
https://www.sau.com.au/forums/topic/381478-rb25-on-boost-at-idle/
THIS
is what you are going to end up with
Really? what about WATER methanol injection... that does not cause this problem.. sure it might if heaps of water got in but a small mist couldn't hurt could it?
water meth is atomsied so it works, Have seen a conrod not 2 weeks ago that looked like the one above due to water in the cylinder.
Sucking water into your engine through a vac line is a new one, and also not the smartest idea in the world.
WMI operates at 150+psi and injects in the order of ML per minute a garden hose into a vacuum line does not operate the same way.
i think its mainly popular in the usa
i was a member of a usa subaru forum when i had my outback and a few ppl on there used to do it
ur supposed to use a thin clean line, warm the car up, raise the revs a little and dip the end of the clear line into some water and suck a little up, maybe 1-2cm's length on a 2-3mm hose
supposedly it'll vaporise a little on the way though the manifold and then turn to steam in the motor and clean the carbon out (subaru's apparently get a lot of shit in the heads/valves)
don't think i ever did it but yeah, just a little info for you guys
maybe i'll try it on my puss-bucket corolla :)
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
