so, is anyone that's posted actually an engine rebuilder or qualified mechanic? Reason being, it was actually a mechanic from a well known and respected tuning workshop that recommended this as a way of removing carbon deposits from an engine we were having trouble with (and no, he did not have a spare engine there he was trying to sell). It is putting water through an engine so I'm not surprised about some of the comments lol, but I have seen it work firsthand and done it several times in different engines, and never had any engine trouble afterwards, no water in oil, nothing. Small amounts being the key, not a gardenhose or firehose, although I admire the enthusiasm there :P
This is why my car never sees a work shop....
+1
Water does not compress well, not a good thing when your squeezing a volume to 1/9th (roughly) its original size.
It just sounds dodgy. The reason water methanol works is because its under pressure and atomised (Like your fuel is when it goes through your injectors). I dont really care what workshop it was, and I dont care how many more engines they've built then me, as far as I'm concerned you dont let any contamination into your engine, wether it be dust, water etc. The photo posted above of the conrod bent, is exactally what could happen if to much water (in liquid form) gets into your cylinder
In sumary:
Water Meth = Yes
Water sucked into your engine through a vac line = No No
I've seen similar done with Ford workshops and their intake/carbon/injector cleaner.
They used to have a tin of spirits(forget what it was exactly, more or less carby cleaner).
Pull off a vacuum line, pull up the recap, and stick it in the liquid.
Never heard of anyone bending a rod from doing it.
Maybe if you used the booster vac line?
And I'm not sold on the water idea.
Maybe some throttle body cleaner???
i was told by a subaru mechanic to put a full can of tb spray through my wrx only beacause the pistons near always sit in oil. on a rb a few small sprays and watch the shit come out the back and your done cant see water cleaning the engine its not made of carpet
I remember back when i had a torana, i used to rev the engine up a little and drop small amounts off water down the carbie and watch all the crap come out of the exhaust.
Done this every tune up i done and no problems. Realistically, very small amounts would form small droplets and go through the engine ok.
I think the method behind it is cold water hitting hot carbon would 'blast' the carbon off surfaces and spit it out the exhaust.
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
