  • Replies 95
Cheers for coming out guys not a big turn out but it was really good to be able to chill out and have a chat to you all, a feed and a drink and a nice peace full drive through the hills thanks guys. there was talk a while ago of a toy run or lobathal lights run i think the olds where keen on it don't know if that's still on the cards
cheers
Jase & Rose
Yeah I'm always keen.
Was actually wondering how many people work between Christmas and New Years, if we could do a weekday/PH cruise then?
Otherwise I'm keen to organise something for January.
Anyone keen on a Christmas Cruise? If we can find a date that everyone is happy with (might be tricky?), I might organise something to make up for my non-attendance last weekend. :whistling:
I am keen, but am going to nz from the 19/12 through to new years. Maybe make up a thread with a poll? and sell me your wheels? <IMG class=bbc_emoticon alt=:whistling: src="http://www.skylinesaustralia.com/forums/public/style_emoticons/default/whistling.gif"> Edited by MOUTH
After bigfellas last cruz I said about a Lobathol lights Cruz then when I seen Jase had got one together that went out da window! An I still missed Da Nismo 34 Cruz :domokun: heading to Lobathol lights for sure this year!! I reckon the Xmas cruz and a Lobathol light run!! :whistling:
+1 for that!!!
I may not be able to attend the next stagea cruise due to not owning a stagea maybeph34r.gif
Sad to hear that Robbie, just make sure the new owner knows that he HAS to attend the cruise's so we can continue to admire the beast
Dont worry, he's been told, but he is a younger lad so he might forget.
Last stag sold from here ended up at lala getting more then a hard time :) more then nice to watch thou.. :cheers: Could just see the bayside blue beast out there now haha hope it does not happen to yours Robbie to neat for that and way to nice paint :whistling: haha
Keen as on lobathol lights run thou .. Show Santa what a r sled looks like :banana:
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
