What brand and weight are people using on their Skylines for the rear diff oil?
I have a '96 R33 GTST Auto. It's pretty much stock accept for high flow, an air pod, boost grounding and a FMIC. I havn't upped the boost or done any other mods to the car.
I saw this thread here http://www.skylinesaustralia.com/forums/topic/317121-how-too-change-front-and-rear-diff-oil/ where is mentions
R33 Standard rear diff - 75w-90
Am wondering if that is what people are actually using, or if they are using something else. I have no idea when the diff oil was last changed, so figured it was time I put some new stuff in.
I'm using G&W Syntrans in my auto transmission btw, which is pretty much identical to the Castrol Transmax Z.
Anyway, wondering what my options are as far as Brands for the diff oil, and the correct weight to use.
Edited by KrazyKong
75w90, 80w90, 85w90, 75w85 all 4 will do as they are pretty much sameness. As long as the gear oil conforms to at least GL-4 (GL-5 is fine too).
If i recall correctly GTST's have a viscous LSD which means the LSD component is sealed and don't need an LSD specific oil, whereas GTRs have hypoid LSDs which require a LSD compatible oil.
Standard or LSD???
If its just the standard rear diff +1 for post above. The GL rating is like a quailty rating and its just 4 or higher.
If its a LSD is more important you must use 80w-140, the reason is because its a hypoid type oil and a hypoid diff has such high pressure between the crown and pinon gears that if it was normal oil in there it would squeeze the molecules out between the pinion and crown gears and not lubricate it.
I'm pretty sure my car is a standard and not an LSD. I don't have the LSD light on my dash. Is there another way to verify what's in my car?
I went ahead and put in some Castrol Rear Axle LSX90 (GL-5) based on a friend having it in their '95 R33 GTST Series 1 Manual.
However something strange is now happening which could be a co-incidence or not. I have an Auto as I mentioned before. The gear changes are smooth, but actually moving the gear selector from "P" to "D", or even "R" is hard to do. I can feel something thumping into place and is directly related to me moving the gear lever in and out of "Park". It's very similar to when you park facing down a hill and the car rolls a fraction when you put in and out of "Park". This happens in the morning mostly, and isn't as noticeable when driving home from work. However the weather lately has been warm so I'm not sure this is a temperature related issue. Previously the weather made no difference even in cold Winters to being able to move the gear selector smoothly.
Is the gear lever/selector directly connected with the Axle oil, or only with the transmission fluid? I had brand new fully synthetic trans fluid put in the car for a service a year ago.
What should I do? Will driving the car damage anything right now? Is my gearbox about die? or did I put the wrong axle oil in. My gut feeling is I might have the wrong axle oil in my car, but right now I'm not sure what to do.
Edited by KrazyKong
Changing the diff oil might (as in just might) make the backlash in the diff slightly more noticable so that when you change into/out of gear with the auto selector, the change in direction of load via the tailshaft to the pinion/crownwheel will result in a little thump as the gears mesh up. Maybe the oil that came out was quite a thick one, or maybe it was a proper LSD oil and so had some different properties that masked the thump.
I wouldn't worry about it.
  • Like 1
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
