17'' ROH wheels 5x114.3 4 wheels 2 tyres good condition 2 tyres need replacing reason for selling is i have just bought a new set of wheels and i have nowhere to keep these wheels not sure of offset. 0420 419 267 <BR>located in newcastle area
$ 300 ono
Edited by updpsi
https://www.sau.com.au/forums/topic/381546-set-of-17-wheelscheap/
