  • Replies 67
hrmm ok cheers the car it came from was a 93 so the duel blades means its been changed at some point so im not 100% sure what it is haha i will take a pic soon but was same as this...
greddy gauges SOLD from my other thread
ok just got our quote back for driveway and need to come up with a bit more coin QUICK so we can get it done before christmas!!!
Turbo $250
Headlights $250
Full 3" turbo back exhaust $300 with free kakimoto rear section so you can choose how loud you want :P
$400 for the 18" mags
$200 for Front and rear seats, door trims and rear trims.
$30 fuel pump
$40 Fuel Tank
$200 Stock struts
Stock suspension arms $make offers
$30 for door windows or $50 the pair
window elec reg/bits in the doors $20 each
clutch/brake/accel pedals $60 the set
complete Hicas setup $80
heaps of other bits here just pm or MSG 0417080960 if interested
ok guys the shell is hopefully going tomorrow i will be taking a bit more off the car then she will be GONE if theres some little bits you need let me know ASAP otherwise it will be gone :P
i still have turbo (conrimed supertight series 2 twin blade comp wheel and nylon exhaust)/headlights/bott with GTR stlye wing, all stock suspension.
pics of wheels need a clean bit of rash but better then stockies :P tyres need replacing $400
Stock suspension dont see any leaks dust covers are rooted but good to have as spares if ya get done by the po po $150 for the set
Stock castor rods $40 pair
TURBO STILL FOR SALE!!
the shell should be going this week so if ya need something let me know asap!
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
