Oh sweet sounds promising. Ive ordered some 245/40/18 and ive also booked it in to get the rear guards rolled and ive got some rear adjustable
camber arms to go in just incase :).
Thanks for your advice.
Blake
https://www.sau.com.au/forums/topic/381557-what-size-tyres/#findComment-6089594
I read 245/40 on another forum and ordered tyres before the reply. But even if they rub i have adjstable camber rods for the rear anyway.
Is it a track car?
If not, adding camber (depending how much) is just going to destroy your tyres in a matter of months, not the best way to deal with scrubbing.
https://www.sau.com.au/forums/topic/381557-what-size-tyres/#findComment-6091118
So, if your tyres rub you can run more negative camber than is needed so they dont rub but wear out the insides in 5000k, wrong.
Still it depends on your set up, what the car is used for, what compound tyres you have and if its lowered to a good height for handling or a good height for looks.
Dude, roll them guards and get biggest tyres that fit without having to sacrifice handling, correct camber not only effects your handling but also your braking.
More side wall will give you a more comfortable ride but will effect the handling if the side walls are not stiff enough, less sidewall on the street will smash rims if you hit pot holes but will give you more clearance and less side wall shift .
Bigger rubber = more grip
http://www.skylinesaustralia.com/forums/topic/84208-wheel-sizes-offsets-for-skylines/
https://www.sau.com.au/forums/topic/381557-what-size-tyres/#findComment-6091128
Wont be running too much lower than it is at the momen which isnt very low. Getting the guards rolled so should fit, even if i do need more camber to stop the scrubbing it
wont be very much at all. Have ordered some nitto invo's and im pretty sure they have a pretty decent sidewall and i dont drive it often so wear wont be a massive issue.
But if i dont have to run more camber to fit them i wont, if they dont rub at all i wont even put the adjustable arms in.
https://www.sau.com.au/forums/topic/381557-what-size-tyres/#findComment-6091151
F ark how it looks, its a skyline not a lambo, how does it handle, and is it street friendly, getting the ride height correct for handling will not only make your car more fun to drive your exhaust won't be left on a speed hump and you can enter a driveway without ripping your front bar off.
Measure from center of your rim to the guard, should be around this.
Front 355
Rear 345
I'm not claiming to be a expert, far from it, its just I've spent a lot of time researching this for my car, with a geometricaly correct ride height my car is a lot better now that I've lifted it up a bit so the suspension can work correctly.
https://www.sau.com.au/forums/topic/381557-what-size-tyres/#findComment-6104479
Thanks mate i will have a look and probably adjust accordingly to those specs because i do want the handling of it to be as good as possible.
I was speaking to a track guy yesterday and he reckons i should probably get adjustable camber and caster stuff for the front too to get it all right,
which i think i might do because i wouldnt mind doing some track days in the near future.
https://www.sau.com.au/forums/topic/381557-what-size-tyres/#findComment-6104620
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
