Hey Guys
Here today we have have for sale my Pride an Joy, She's a R33 Skyline iv owned for awhile now but Unfortunately with me just starting a apprenticeship and needing a Ute money will be getting tight without adding another rego thus the missus says we have to many cars and she needs to go, the car not the missus .. This car has been my daily drive to and from work (Mostly highway Km's). Dont try to low ball me iv done my part puttin it up for sale if it dosnt sell im more than happy to keep. Contact me on 0430478910, I do not take calls during work hours so if you want to get in touch send me a SMS and ill get back to you asap.
Coil overs all round - Currently sitting higher to get up my driveway can be dropped on its ass
Aftermarket Exhaust - Nice note to it.
Fresh Paint Job (not a closed door can job) in a Custom Metallic Red me an my painter mixed up. The car was faded the body was perfect you wont find bog.
**Rims** Yokohama Model 6's 17" wrapped in semi slicks (will come with the car for the right price if not i have another set of 17" black and chrome to go with it)
The Turbo was rebuilt just over 20 thousand k's ago removing the ceramic rear wheel adding a stronger metal one to handle more boost but i never got around to installing a boost controller as it has enough power to put a smile on your face, so its never seen over stock boost levels.
Original Skyline 5 piece floor mats hard to find in good condition.
New Belts and Air con Compressor wheel !Air con works!
serviced religiously this is my daily drive i treat it right and iv never had a problem with it.
Apexi Pod Filter
platinum plugs and upgraded coil pack.
I will take you for a drive around the block so NO TEST PILOTS unless you have the cash in your hand
May consider swaps for a GQ/GU TD42 Turbo Diesel Ute/Wagon
Price is somewhat negotiable
*****PLATES ARE NOT INCLUDED*****
s13 180 drift drag rb20 rb25 rb26 31 32 33 34 35 gtr rx7 rx8 patrol hilux
https://www.sau.com.au/forums/topic/381563-fs-r33-custom-red-one-of-a-kind/
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
