Using Photoshop CS4 and the clone tool moves each time you apply it. Thats OK, meant to happen, but when you lift and then start again it doesn't go back to the original sample location [like in other packages I've used]. Is there any way to get it to return to the original sample location every time you lift the mouse button?
BTW I'm doing an old photo with heaps of stains and creases in it, normally I would use photostudio which is a simpler program, but this time the photo is that bad that I need more tools and smoother blending/dithering ability.
See attached.....its a mess, but I reckon I can still get something decent out of it. But this clone tool is frustrating me a bit. The healing tool is excellent though.
https://www.sau.com.au/forums/topic/381567-clone-tool-question-photo-shop/
here it is
You want it to be unchecked for it to restart from the clone point... or whatever it's called.
If it's ticked, it'll spawn relative to where the brush is pointing
Edited by SKITTLES
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
