Fs Melb:: 1992 R32 Gtst
Definately selling now...
Need to make way for a new car.
Make: Nissan
Model: R32 GTST Type-M
KMs: 99000
Colour: Black
Asking Price: $13000 asis 4 months rego
Email: [email protected]
Phone: 0431 076 366
Rego: 4months
Mods:
-Dr_Drift tuned ECU (tuned to run 13-14psi)
-Bleed Valve (Currently closed to run 10psi)
-Autometer 2.5inch boost guage (upto 20psi)
-Full 3" Exhaust from Turbo back
-CUSCO front strut bar
-Exedy racing button clutch (put in last year)
-KYB street tune damper adj. suspension
-Simota POD filter
-New brake pads on the rear Bendix Metals
-Front pads at about halfway so still plenty of life in em
-Stock wheels
-Genuine GTR Alloy guards
-GTR front bar (fibreglass)
-Tinted windows (rear qtrs are mirrored)
-GTR Front seats (in excellent condition)
-Black and Red interior accents (dash, center console surrounds and door bits)
-Autotechnica steering wheel
-RAZOR steel shift nob
Will throw in the kenwood MP3 player with pioneer splits and 6x9s worth 1k
(not installed, pulled it all out cause i was going to put something else in it)
Car was taken to calder about 5 months ago and ran a 14.08 on 10psi.
pics here... http://aussiewheels.com/profile/View.php?ID=102
dont have webspace anymore to upload them :P
but yeah it has stock 16s on the front... the other 16s are bald from the front before i got the wheel alignment done.
will put them on the back and keep the 17s for my next car for drifting so whoever buys it will need to get some secondhand ones for an RWC.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
