When I hold my foot on the break to come to a complete stop, hard or soft, the car after it hits a certain amount of revs it kinda pulls the car forward as I pull up at the lights.
If I just hold the break peddle down quite hard the revs drop a fair bit and than pops back up. You feel the car being pulled a bit more forward without doing anything different. Whats the go? Lol. I have to, after I press the break paddle, loosen my foot off the peddle so the car doesnt drop in the revs. Still pulls the car forward...
Also another thing that might have something to do with that ^^^ I was driving it the other night not fast just normal and I felt it lagging pretty bad like it didnt want to idle any higher than all of a sudden, I stopped at the traffic lights like normal and pulled off from them and the car struggled to even move. I pushed the peddle all the way in than all the way out. Nothing! It moved but not very fast or even above 20km/h. It was like dying on me I swear. I was so worried cause I dont know what it was.. Its happened once before yet ive only had the car what like two weeks. I turned the car off straight after it lagged like that for about 10 minutes and it was fine but I know it wasnt normal. Hate stressing bout it :(
https://www.sau.com.au/forums/topic/381663-is-it-normal-for-this-to-happen/
Well I need new bearings but no where is cheap enough for me as im struggling a bit on money... :S Does that mean anything? Do you recon the full body throttle needs a good cleaning?
Have u ever tightened the accelerater cable at all?
It was in snow like the setting haha. Maybe that had something to do with it lagging... mmm lol. and Im wondering if theres some sort of non stock system put in my car where if i just sit there in drive the car randomly tries to go forward with me just holding the break and ive noticed if i pull the steering wheel to the left or right it does the same thing where it revs up and tries to move the car forward like it wants to go somewhere but im not doing it. Really weird.... Does anyone know what it could be? Thanks
Ok, resisting the urge to make fun of you being a woman right now, I'll try to help :P
I don't really understand your description of the first issue, so I'll leave that one alone. The second issue, the lagging, sounds like a misfire. Especially if it stopped after you turned the car off and on again. So did the car sound any different? Like a WRX sort of sound? I would be checking spark plugs. Potentially coilpacks as well but that's generally associated with high rpm misfires rather than low load.
As for your last post... It doesn't sound like there is any actual issue there. Automatic cars will move as soon as you take your foot off the brake, that's the stall point of the torque converter. And turning the steering wheel in a car with power steering puts load on the engine, so the revs need to go up with it.
Of course I may have completely misinterpreted your descriptions and I'm way off lol. If you could get a video of said problems then that may help thumbsup.gif
Yes I may be a girl but I do know a bit about cars just the things I post on here im just double checking that its all good :blush:
Yes I understand that whole thing with autos its just in my last car which no wasnt a skyline but it never did anything like that. Older yes and not a drift car haha. So I talked to a mate of mine and he said its not normal for the revs to go up like it did.. Just sitting there the car tried to pull itself forward when I did absolutely nothing.. It does it sometimes.. You see the idle moving a bit to.. And I did a service on it thinking it would do something.. The car just runs better but does the same stupid shit lol. The sprak plugs were chenged, oil and coolant and filters and the coil paacks are new so no problem there.. I thought the revs doing that was normal for a skyline because i thiought it does it to help you turn corners but the whole just sitting there on the spot the car tries to go forward on its own aint normal haha
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
