19x10
Backspacing - 6.89"
Offset - 35mm
Bolt pattern - 5-112/5-114 (universal)
I am wanting to use the above wheel for front and back.
Has anyone here used a 10" wide rim with +35 offsets for fronts, what size tire you use?
Need to know asap :)
Thanks
https://www.sau.com.au/forums/topic/381734-will-these-wheels-fit-or-too-big/
Thanks guys
I will check if they have that size, if not is 255/40 ok? and 295/30/19 for rears?
Does having a wheel that big in front affect turning circle and would i need a spacer?
It will prob stick out of the fender at front but not at back.. how do i calculate if that will happen?
Cheers
You know I am Jon lol, thanks man.. So is yours =] convince your wife to slam it...
They'll have 255/35/19. I'm running that on rear .. Federal 595 evo's . Running a 40 profile on front and 30 profile on the rear will look weird your front will sit higher at the front and lower at the rear. Car won't look level.
255/40 might be a bit tall and cause scrubbing depending on your height. Offset will be fine for the front, throw some neg camber in since you're planning on doing track work anyways IIRC.
255/35 fronts and 285/30 rears would be my ideal tyre sizes for the width you're running and for trackwork.
These are the two calculators I use frequently when choosing wheels and tire profiles.
Wheel offset calculator - use the specs on your existing wheel as the comparison to see how much inner and outer clearance you will have with the new wheels
http://www.1010tires.com/WheelOffsetCalculator.asp
Tire Size calculator - used to ensure you do not deviate too much from your factory overall diameter as this will affect your speedo. For V35s I normally use 225/45/18 as a base comparison.
http://www.1010tires.com/TireSizeCalculator.asp
Thanks N15mo!
Bee they are out of stock in the 255/35 so unless i wait i only can get 255/40
As for rear if i was gonna go to a 30 profile id go 295 but everywhere on g35 driver says 30 profile too small?? most 295 only have 30 sidewall so its that or go down to 285/35 and be closer to the 255/40 or get both same 255/35 and 285/35.....
I have a set of 245/40/19 and 285/35/19 un-used still being shipped over in these Hankook tires if anyone wants to buy the set let me know so i can choose other sizes !
Edited by R6n350GT
Oh Bee/n15mo, what if i went 265/30/19 for the front over 255. May do that to keep both wheels at 30 sidewall. But 4DGS if you let me know about how sh!t 30 is over 35 and 40 and convince me to go 255/40 and 285/35 .... rather not but you know much better than me !
Edited by R6n350GT
Reading this thread made my mind up
http://my350z.com/forum/wheels-and-tires/339585-295-30-19-rears-but-what-fronts.html
265/30/19 and 295/30/19. VDC will be happy, yer the car will look higher due to small sidewall but i can always lower it a bit :)
So my 245/40/19 and 285/35/19 Hankook V12 EVO are up for sale, plz make an offer.
C&D review said they are close to PS2 s!!
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
