  • Replies 160
Posted Images
handheld pano while hanging out in a tree today. love this place, only a few minutes ride up the bikeway.
(click to zoom)
love the pelicans
(click to zoom)
and, while i was on the top of this...
i took this...
:P (click to zoom)
EDIT: Also love those shots Micheal
Edited by Jay019
Michael shots look great - some CC maybe set the white and blacks in either photoshop or lightroom to give the image the full tonal range. The images look great just lack that little extra punch!!! Only being super critical anyway
Valencia Spain
DSC_4858_59_60 by joshua.matthew.fitt, on Flickr
Prague Castle
DSC_0128 by joshua.matthew.fitt, on Flickr
love that first one Josh!
but any reason you used auto white balance in the bottom pic? would look awesome if wb was set properly (and horizon was 1/3 or 2/3 instead of in the middle)
Edited by Jay019
to tell the truth i have no idea about how to set the white balance correctly for a shot like that let alone at all. The castle shot was really hard as the lighting was from so many different sources and so many different colour temperatures :( Want to teach me haha
with night scenes tungsten seems to work best i found. on the D90 the white balance button is on the back (3rd from the top on the left, labelled WB/?/Key) just press it and give each setting a try. you'll eventually get a feel for which one works best in which light. i remember on the d90 you can set the white balance as a K value, that helps really dial it in, just give a few different settings a try. ken rockwell gives a good rundown on white balance. all i know about it is the camera tends to need a hand in artificial light. http://www.kenrockwell.com/tech/whitebalance.htm
EDIT: Nice Rhys, some sweet shutter dragging going on!
Edited by Jay019
Valencia Spain
Prague Castle
these shots=awesome
love the bottom one....
Some randoms from recent shoots:
So the girls wouldn't let the groom into the gurdwara unless he payed up. So after a few minutes of haggling a price (which the girls declined) he decided to get his credit card out. Priceless moment!!
Experimental shot using some strobes at the getting ready shots.
Trying a square crop:
Had a huge success from my first photobooth session :) Cant wait to do another one. Even a 3m wide roll wasnt wide enough for big group shots.
Will post up more soon. But the shot below is just showing my setup.
One of my corals:
Edited by siddr20
i grabbed a couple shots of the sky yesterday too. was awesome. i reckon we might get another one today. I remember it happend last year about the same time and happened for 2 or 3 days in a row.
love the variety and quality of this thread!
went for another ride to the onka river. looks like it will be a daily thing for me. actually got off the bike and walked out onto the swamp area for a few shots...
Nice capture there CPD.
Jay - Love the 1st and the last one. The simplicity and vibrancy is awesome.
Richie - Cheers man. Those are just randoms I have posted. Hopefully get the blog updated soon. Ah nice shots of the skylines there. I see you been trying that toy look type effect. eg) 6231 and others. Nicely done.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
