  • Replies 160
Posted Images
I have always wanted to stop on the way down to the snow every year at a random field and just shoot a tree within the landscape. I'm going to actually do it next year!!! Been wanting to do it for so long.
Cool shot Jay!
A few snaps from SCC2011 I just did up (some yesterday on a main link, but thought I'd show my fav's)
Notice I have myself a new little 'rg photography' tag like everyone else now... lol
Damn peer pressure :P
post-50568-0-17768500-1321947699_thumb.jpg post-50568-0-10852500-1321947727_thumb.jpg post-50568-0-55025600-1321947790_thumb.jpg
woohoo!!! welcome to the world of pro photography :P
Matboy, love that tree shot of yours.
Specially the square crop (i know, im a sucker for the square)
oh, and Sidd, this is awesome!!!
experimental shot:
did you direct her to have her face where it was, or was it a lucky coincidence that the shadow lined up perfectly with the cheekbone? either way, worked out sweet
Edited by Jay019
It was a coincidence as I only took 4 shots and that was came out perfect. If I had more time I would have tried to get it perfect.
Thanks for the kind words man.
Kory - Bare 580exii for the lighting :)
EDIT: Nice Rhys, some sweet shutter dragging going on!
Cheers Jay! I'm slowly getting better. The 70-200 Non-IS isnt the easiest thing to try and drag! Maybe one day when I finish my Patrol and S14 projects I can afford a 70-200 2.8 IS... Maybe :P
Signatures make your photos look 10% better ;)
double post, sorry. i just wanted to show this off, lol. a local stencil artist contacted me about creating a piece based on this photo...
well it is now finished and is in a gallery in adelaide at the moment...
i was blown away when i first saw it. cant wait to get in there tomorrow to see it close up.
yeah, not wrong. i should let him know. he spent over 40 hours on making up the stencils (10 layers) and then 5 hours in spraying it. hope he gets a few sales at the exhibition, I love watching his work evolve.
Some really awesome photo's guy's.
I love that even though this is a car forum a lot of photo's are not of cars.
My friend who just got me into photography just developed some film shots of Sydney and some other random photo's. It's amazing to see and I really makes u appreciate what a beautiful country Australia really is. I think we are all extremely lucky that we have such a beautiful place to call home.
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
