  • Replies 160
Posted Images
hey guys new to the forum and new to photography and editing so heres my go at editing, please feel free to give feedback good or back cheers
this was taken with a canon 1000d 55-250 set at 55mm
Edited by ndxxx
cool mate...
you will rarely get 'bad' feedback from anyone here... everyone seems to appreciate many different styles :)
If it is 'bad' feedback it's generally with the aim of helping spur improvement, and not 'i'm better and your shit'. it's pretty cool and friendly in here, so post away and join the team :D
nice work Jay. that's awesome!! You know where else that would look rad... bottom of a deck! bad arse youngling on the bottom of my deck!
I ended up submitting that 'art house' B/W water splash shot into a comp. doubt I'd win anything but still, a bit of fun ;)
Here's some other shots from the set. I'm not generally a people shooter so advice/comments/critisms are super welcome!
Artily "Art - ill - E" (I just made that word up) I call the series simply... BEN. ooooooooooooooooooooooooooooooooo. Please picture me in a turtle neck and berrae.
and the original (and submitted shot)
Just trying new things richie and seing what is possible. Probably looks like that too since the colour temp has changed.
Matt - hahah how did you make him stand there? I would have run off or got a bigger hose and soaked you in it. Goodluck with the comp.
I did a model shoot yesterday where I was throwin milk at her :) Give me a week or two to edit the image. Stay tuned!!
Edited by siddr20
skin work:
So beautiful! Wish i knew how to fo this!!! Have to find and search out some tutorials one day!
Bit of a snap but i sorta like it
DSC_0152 by joshua.matthew.fitt, on Flickr
I like it Josh. Where is it? They all just need to be wearing monk outfits or something... descending into some sort of abyss...
Its sort of funny you say given its in the Vatican Museum inside Rome haha!
Thanks for the kind words Josh.
Just keep at it and you will get there. Best way to learn is to just go out there and start taking pics and mucking around with different lighting etc.
Love the pic you posted!!! Where was it taken?
Just purchased a Canon s95 with a Canon underwater housing :) Can’t wait for my end of year trip when I go snorkelling. Will be testing it out then.
Hope taking pics underwater is easy lol..Any tips for those who have done it?
Edited by siddr20
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
