Hello all, Rego runs out in a couple of weeks (11th of November) and trying to get this blue slipped in NSW appears to be a hard task for me.
This would suit going back to QLD for easy re rego, dedicated trailer/drift car, or parting out, as i know there is an easy 5k Parts to be stripped, i just dont have the time or money!
Need to pay bills for more Video work.
Gloss White.
Rear spoiler removed
ZTune fibreglass Bonnet
R34 GTR Copy front bar
Final Konnexion side skirts
Veilside rear bar
40mm pumped GTR rear gaurds
33/34 conversion front fenders 30mm
R34 headlights
RB25DET Series 1
Guessing 135km on engine, 165km on Body - Odo doesnt work.
Series 2 RB25 Gearbox
Tight tight LSD
Exedy button clutch - Pretty brutal.
RB25 Turbo rebuilt and hiflowed by GCG
Full 3" mandrel system with Straight pipe
CES racing split dump pipe
Hiflow cat
Walbro intank 500 hp fuel pump
Front Mount Intercooler
Mictotec lt12 ECU
Microtec ignition module
Bocsh indiviual coil packs
Battery in Boot.
Cold air induction pipe channelled into the front bar
Two stage Manual boost controller 10-16 psi
Car apparently makes 328hp on 16 psi
Stock unmolested interior,
Drift style steering wheel
Nismo short shift kit
Sony mp3 front aux head unit
Alpine fronts Speakers
Sony Xplode Rear speakers
Sard bov Behind front bar, but currently blocked off for fluttz
JIC Magic base height adjustable coilovers front and rear
Ventilated front brakes with new pads all round
18" koya rouge wheels
new rubber on front
60% rear
$6k Or near Offer NO TRADES! Unless R31 4door and 5k Cash my way
Please text me 0424505711 NSW Sydney - Northern Beaches
Thanks! Scott
Edited by VashR31
https://www.sau.com.au/forums/topic/381748-r334-skyline-widebody-cheap-6k-ono/
