Engine
-RB20DET-$1000
Engine is healthy and starts first time every time
Comes with Power Steering pump Alternator belts still on
-Exedy Heavy Duty Cushion Button Clutch
-Intake Plenum+ Throttle Body
Engine Service Details
-Motul Turbolite 4100 oil, always changed after every track day or 3000kms
-either genuine nissan oil filter or DRiFT magnetic oil filter
-HKS 600cc injectors-$400
-Hybrid FMIC KIT
With HKS SSQ BOV / Genuine HKS Purple fin also, Piping and joiners to suit R32 -$500
-Z32 AFM-$250
Apexi RX6 high mount turbo kit, Includes
-Lines
-Dump/Front pipe Custom Made
-Greddy/Trust steam pipe hi mount manifold
-Greddy/Trust 48mm wastegate
-HKS Mushroom filter
-Alloy Intake Pipe
Price - -$1600
RB20DET Garage 7 Nisstune Remap Ecu Tuned on E85 Fuel -$200
Afternarket Alloy Rad comes with Spac push button Valve cap-$350
Catback Exhaust straight pipe til cannon at rear Suit r32 and s13 as they are very similar- $250
Interior
-R32 Sunroof Model Safety 21 7 point cage+ Tabs for side intrusion (no bars have been made for this) - $900
-Greddy Boost Gauge -$60
-Trust Grex Diamond gear knob -$50
-Drift Buton-$20
-Stock 32 GTS Seats-$80
Suspension
-Kei office coilovers, damper, height and spring adjustable, go nice and low - $ 850
-JJR 30mm Front And Rear Sway bars.-$200
-JIC Adjustable rear camber arms-$200
-R32 Cusco front camber arms non adjustable -$200
-Kazama castor rods-$200
Parts located in Melbourne SE Suburbs - Not really able to offer postage at this stage
Pics
http://nissansilvia.com/forums/index.php?showtopic=512863
https://www.sau.com.au/forums/topic/381755-stripping-r32-track-car/
