Rare Nismo For Sale!
I thought it was just if “the modification effected/caused the incident”
Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
Yeah, they'll find anything they can. "Oh aftermarket ecu, that doesn't comply with emissions" lol.
See, I still thought it was 10 posts, and she was at 7 so I couldn't be bothered going in and fixing it when the fix was to simply post 3 more times. 8 more times....perhaps I should have.
