how the hell would those tyres cope with 1000hp, let alone 2500hp? :wacko:
Dunno about the tyres but I would have a silly grin on my face the whole time
Actually, if it was a 10 lap race around the Nurburgring, I would put my money on the R35 any day of the week. Im not saying that this thing doesnt look brilliant (the rediculous turbo's sticking out the front make me happy in my pants), but seriously, you might as well be saying that this Supra is quicker than an F1 car simply because it has more HP.
Does it look like a circuit car?????
  • Replies 62
My point EXACTLY! Horses for courses. Which is why I was saying that your first comment about waiting for R35 owners to come and say that their car is faster for some gay reason was silly. You are the one who made the comparison, not me. That Supra is probably faster in a straight line than a hell of a lot of supercars, would it beat them around a track? No chance in hell! Is it awesome? F'ing Oath!
If you do want 200hp and A/C though
Go see Nelson Racing
This is the car that Batman would trade the Batmobile for!!! Or just sell Robin's ass on a street corner and keep both......
fap?
unfortunately, apart form the turbos ,its still butt ugly Supra at the front..
But this is possibly the sexiest rear I have seen on any car ever..and seeing as its the only view most people will ever see that is all that matters
i could really see myself commissioning a car like that camaro or supra as my daily driver, given the budget. you'd probably still want a back-up vehicle, but still. Cars like these might be pretty popular for us car guys in 20 years, as it gets harder and harder to DIY maintain new cars.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
