Hi,
Can anyone help?
I am after an "idiots guide" to these following numbers. I know its for changing the boost but it will allow you to change both?!
I appear to have put my manual "somewhere safe" and can't find it.
Thanks in advance...
G.
https://www.sau.com.au/forums/topic/38185-regarding-powerfc-boost-control-kit/
The second numbers you have highlighted is the Duty Cycle. This is basically the amount of time the solenoid stays open (bleeds) in realation to the amount of time it is shut and allows boost pressure to the wastegate. It is expressed as a percentage.
The minimum you can set (from memory) is 10%, which would be sending boost pressure to the solenoid 90% of the time, bleeding 10% of the time - it would be used for low boost pressure.
The maximum you can set is 90%, which has boost pressure going to the wastegate 10% of the time and bleeding 90% of the time.
If the boost is spiking (I would put money on it in your case, those duty cycles seem very, very high for those boost pressures), you need to adjust the duty cycle down.
If the boost is lazy, or it isnt reaching full boost, you will need to adjust the duty cycle up.
If you change your boost pressure up, adjust the duty cycle up at the same time, if down, adjust the duty cycle down. The power fc has a self learning mode, which will optimise the solenoid actuation for optimum boost control BUT, if you are miles out of the ball park, it wont have a chance. For example, if I adjust my boost pressure up by .2KG, I usually adjust my duty cycle up 4%. then just monitor on the peak hold, if it is spiking (more than .1kg) I will adjust the duty cycle down by 2%. If it isnt getting to boost, I adjust duty cycle up by 2% at a time, until it is just spinking a little (less than .1kg) - from there I let the power fc learn for itself.
If you ever need a copy of the english manual (although its for an RX-7) one is available on line at he apexi usa website, look under electronics, then documentation or someting like that.
  • 2 months later...
Is it also true that running boost above 1 or 1.2 bar using 3rd party boost controller and PowerFC will cause your engine check light on the dash to light on, because PowerFC could not monitor the boost anymore? The only remedy is using the dedicated Apexi boost control option that connects straight to the PowerFC, is this true or not?
The 255 value is the 'learning value' isnt it?
Not quite sure what it corresponds to so I think it is more of an arbitrary value than anything else. I can tell when mine is learning cos you can see this value changing & then it stays put once it has learnt.
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
