Hey guys just wanted to see if anyone is up for a meet up..:)
Place: Kings carpark ( 366 boundary road Dingley Village 3172)
Date: november 11 2011
Time: around 11pm
Basically just wanted to see who is up for a meet and show your ride that night and maybe play some
pool depending on who wants to play or have a mini cruise somwhere..:)
good for people who lives nearby so we can chill often too...:)
But everyone is welcome should be fun!...:))
https://www.sau.com.au/forums/topic/381855-kings-pool-place/
unfortunately for me my uni doesn't believe we should have a break from exams on weekends. So Saturday exam to come the the after this
Damn.... Your uni is cruel lol dont remember my uni to be that strict....ermm
So you finish on satday for exam yeh?
Wouldn't mind a meet and possibly a cruise/shoot some pool. Kinda depends when I get my car back on the road too I guess :(
Yeh man should be heaps fun....u got 1 week to get it back on the road :) or just come down with just for the night just drive inbetween me and my mate so no police can try to pull you over lol
Sounds good mate. I've got the car back on the road today so should be all good :thumbsup:
The only other thing is that I work Friday nights and usually finish at around 10-10:30pm. How many people you've got interested so far? If not too many yet, wanna change it to a Saturday or Sunday night instead?
Cool congratz mate toatlly agree with you man due to exams people cant make it....satday is aight with me just hoping peepz
can still come but il still be there on friday night incase other peepz rock up :)
Sounds good mate. Shoot me a PM cos I just tried sending you one but it doesn't work :down:
Yo my bad for not getting back asap yeh should be there tonyt and we can decide what you guys feel like doing :))
Il be there at 11:30 tonyt :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
