I didn't notice at the time, but have noticed now that the rego papers for the R32 that I bought recently has 2002 on it for the year, whilst I know that it is a 1992. I am hopefully getting it reregistered very soon, but am wondering what is the possible ramifications of this error on my rego papers? None? Could it mean something crazy like voiding my green slip due to the wrong information? Will it be a beauracratic nightmare getting the RTA to look into it? Anyone one who has experienced something like this, advice on what to do about it very welcome.
Thanks.
https://www.sau.com.au/forums/topic/381869-rta-year-of-manufacture/
I don;t think it matters generally.. I've heard of other cars having wrong details on the rego papers such as hamiltonau's R33 gtst being down as a R33 gtr v spec, as well as my r33 being a sedan on the rego papers when its a coupe.. I asked a lady at the RTA to change it and she was pretty much like 'meh, it doesn't matter'..
Hmmm yeah, just a different century.
I spent weeks trying to confirm this.
i have a 96 R33 with 2006 marked rego papers. I couldn't find anyone in the RTA or an insurance company to go "yes, you are valid AND insured".
I had 3 out of 5 RTA staff members hand me change of record documents "just in case" the others gave me the RTA hotline. (What can indians tell me the RTA Teller cant??) I probably spoke to about 15+ staff members at 4 or 5 different RTA's from blacktown to Nowra.
eventually i found a family connection to an RTA inspector that said that compliance dates need to be on the rego papers and the inurance co needs the actual manufacturing date.
the simple version is that RTA work on logs on appearance in their system and Insurance works on car details or something like that.... it was explained but is much more complicated than you'd think.
I have no doubt that it is insane and complicated when it shouldn't be, that's why I came here instead of straight to the RTA. I was at my mates' working on some panels today and I had a look at the compliance plate, and it was complied and registered the first time in 08/02 so I feel a bit better about it since those dates match up.
Fark that. If someone on the other end makes a mistake, I'm not going out of my way to change it.
Eg: ATO has my birthdate wrong by one day, and I'm not writing them a letter to fix the mistake they made.
Agree - Dont worry about chasing and changing it
Also in regards of ATO - I am 2 years older lol that's a mistake
When I first registered my R34, it was listed as being a 2011 Nissan Skyline R34 GT then I got a call the following day from the Manager of that RTA telling me that I needed to come in because the trainee didn't do it properly, she didn't even take a copy of the VIA, then they issued me with a new rego label and I had to destroy the one they f**ked up.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
