so here's what happened...
this morning i went out to woolworths to get my groceries. all was well. came back, parked, no problems. this afternoon i go out get in my car and it wont start.
-i turn the key the dash lights up
-there is enough power for locks to work
-stereo works
-but when i turn the key there is just one click.
so i thought battery, figured i had left something on accidentally, but couldnt find anything. look at the battery, its an old one. so i figure i'll grab a new one. Another car boosts me, my car fires up no issues. but my battery light is now flickering. but i drove to battery world and got a new battery. dropped in in right in the parking lot, and nothing, car wont start, doesnt even crank, just that one solid click. another car boosted me again, she fired up no problem.
the whole drive home battery light on dash was flickering. I am assuming that this is an alternator issue? anybody have any other ideas. i tried to be as detailed as possible.
alternator fits because of the battery light, but i am worried about the fact that it wont start up even with a new battery. the alternator should just charge the battery once running, but the battery should be able to at least crank it a couple times, but all i get is a click.
any insight would be much appreciated.
https://www.sau.com.au/forums/topic/381890-r33-no-start-alternator/
Have u checked the main harness like earth on the block ...and power wire that goes to the alternator ?
Also check main fuses in engine bay !
Does sound odd it won't start with a new battery
Does sound a bit odd, when my alternator died a new battery would start the car so I would check other places like in this quote
you need to get a multimeter and do some checks.
Firstly, put the probes across the battery and set multimeter to DC voltage and do the following:
when the car is stationary (key off), should be about 12.4V (good condition, charged battery)
Key to Cranking (wether the car cranks or just makes the click) and record the voltage
If you can get the car running, record the voltage while the car is running
Do this and then post up your results
i am ready to begin tomorrow mornnig...
that is my plan, i have a multi-meter... test light, and a handful of the cheapest tools money can buy (courtesy of supercheap auto).
i have 2 batteries, 1 new one and one old one. after throwing in the new one and getting the same problem i am betting that both batteries are good. more likely than both being bad.
so i'll check battery with car off, check battery with key on. i'll use the spare battery to boost the car. and i'll check voltage again. if its still reading 12ish, and hasnt jumped to 13-14 i'll know that its not charging and is running off battery.
that would point to something to do with alternator, but as i sit here running things through my head i just cant seem to fathom why a alternator short would stop my car from starting with key... and why only boost will start.
its definitely not a starter.. she fires up instantly with power from jump start
i was thinking maybe a loose wire under the dash, bad signal from ignition, but that wouldnt explain the alternator light. but the alternator doesnt explain my no start.
i'm just in a locked carpark, and the lighting is really shitty this time of night, or else i'd go and dive in now. instead i just wont sleep...
also, even if it was just a bad alternator... i drove the car this morning. no battery light, tried to drive this afternoon and wouldnt start after trying two batteries. if it was an alternator, the car would have started, initial battery should have had more than enough juice to start the car, and drive around for a while. this all seems to point to an electrical short somewhere. i hate electrical problems... i'd much rather be drilling out a broken bolt... at least then i know the problem and how its going to be fixed.
where are you connecting the jumper cables? bad terminal on battery and your clips are helping squash on?
if alternator doesnt get a good connection to the battery it will overcharge which will prob bring on the warning light but im not 100% if that applies to skyline alternators
only thing i can think of atm that explains both your sypmtoms :thumbsup:
Edited by t_revz
well, i went out this morning.
both batteries are good. new one in the car read 12.5, old one out of the car read 12.3.
test light told me there was power getting to the alternator. i then used hte old battery to jump the car. and the battery in hte car now read 12.4. so the charging system isn't working.
i also checked all my fuses hoping for a long shot but all the damn things were good.
if your in brisbane pm mate, im a mobile auto sparkie, can help ya out
thanks for the offer, but i'm about 1.5 hours south of you. i think that puts me a little out of your range.
well, battery is in the boot, when i jump it i hook up to the positive post under bonnet, and a bolt from the strut for earth. and the terminals are all good and tight, just dropped in a new battery last night thinking it was just a battery problem. oh well.
can anyone else throw some ideas at me?
Positive post under bonnet? Or on the battery in the boot?
Sounds like one of your leads is dodgy (probably earth). With the battery in the boot you need good quality cables all the way from the battery to the engine bay.
Unbolt the earth lead from the battery and wherever it attaches to earth. Clean the terminals at both ends (remove dirt, rust etc) on the cable and where it attaches to earth, and refit. Tighten properly. do the same for any earth straps in the engine bay. This should fix the problem.
yea. i've been looking at everything, but everywhere i hit with a test light seems to light up no problem. i've been checking my earths by hooking up to power and then tapping earths and its lighting up. this is quite puzzling.
i'll check out labrador auto
Testing with a 5W bulb in a test light won't tell you what's happening when you're trying to ram several hundred amps of cranking current through the starting curcuit. You need to unbolt the terminals of the earth lead and physically check / clean them. I've seen this problem before with poor earths. They run low current fine, but increase the current and they play up. The fact that it starts properly when you're using a different earth (and possibly positive terminal) hints that your problem lies with poor contact.
Perform all the tests i said. checking just the battery voltage will tell you next to nothing apart from if the battery has dropped a cell or more
Crank and check voltage (get another person to check it) and tell us what you get
A stuffed alternater will not stop the car from starting on a fresh battery
Has your stater been out recently?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
