Guys, be fair
The R33 diff is a common conversion into BA falcons in drag racing and speedway circles. The trick is, that you need to use a front diff out of the GTS4 (NA). This will bolt straight in but you'll then have to convert the Falcon to 4 stud at the back. You'll also need to fit the Skyline steering rack and lock it out, but this has the benefit of giving you adjustable toe on the back of the Falcon. If you're half smart you can put a tee line into your power steering return lines, install a couple of electric solenoid actuated pilot valves and connect this to the unused terminals in the Falcon ECU to give you HICAS (you;ll need to call your local Pirtek dude to make up the hyd lines for you, as the Skyline and Falcon hydraulic fittings are different - Skylines use 1/4" BSPP and Falcon uses 3/8" NPT). Again, a little known fact that Ford played around with HICAS style rear steering, but gave it away as too costly on their budget spec taxis.
True
u wouldn't happen to know what the difference is between the front and rear diffs out of the skylines.???
The front diff is in the front and the rear diff is in the back
the front diff is open but you can convert it to LSD with a Phantom Grip assembly. To increase the locking, you use coarse lapping paste between the faces. Note you'll need to build up and machine the faces every 5000km because they'll wear out so quickly.
Problem.jpg?1236877228
Actually you would be better off putting the below diff into your Falcon..
Komatsu HD785-5 Differential Assy
100% guarantee that you will not break it!!!
yeah cheers for that cuz i really needed another wanker telling me wat to do.... shut up unless you can make a good point about what i'm trying to do!!!
Oh dear!
Not my fault you drive a tractor... Just out of curiosity, have you asked this question on the ford forums?
Why do yo9u want to? Why not just put in a falcodore clutch type LSD and be done with it. The viscous LSD isn't all that great and any entry/mid level aftermarket centre you will get for the 33 diff will be clutch type anyhow. Grab a rebuilt Falcon LSD, chuck it in and bobs your uncle.
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
