James, Ash and Andrew hope you planned a couple of rest stops along the way, as shivam and myself went for a test run yesterday and he experienced major brake fade just after the down hill sections.  Jumped out of the car to see the front calipers SMOKING ;).
Remember we are on a cruise... not a race-track. So we wont be doing heaps of high speed braking like i bet you guys were doing ;)
I didnt get any fade on our drive... and i've got undersized disks and worn pads on my car.
We wont be going fast enough to possibly have anyone with brake fade.
Unless thier car's brakes are shot, then that's the owners problem.
we already have a resident R31 to poke poke fun at. Actually, its moreso the driver that we poke fun at than the car.
I believe Ash's R31 coupe
Hmm... I'm taking this as yet another punt at me :P
And yeah, the take the usual p(ss outta me... but not the car as everyone knows it's a rocket :D
Dunno if my car will be coming yet, dropped it off at centreline this morning so we'll see how it goes.
Either way i'll be there somehow!
  • Replies 205
Evil, can u bring CHOBITS PLEEEEEEEEEEEEEEEEEEEEEEEZE... I lub u long time, n all those who ordered CB's can pick em up on the day. I'll take the liberty of takin em out of their packaging n charging them up soyou guys can use em on the day.
ok sweet shan :) and i will have money and a nice nipple rub ready
also
anyone wanna bring stuff and chuck in the back of the 4wd can do so, depending on size and if they dont mind it getting battered around etc
anyone bringing a bbq? whats goin on for food?
Funky - its not 270 x 2. The cruise is kinda one big circle. So the whole cruise (well from Major Petrol station to Major petrol station) is 270 and they both just out of the CBD. We don't do any doubling back the way we came from on this cruise.
For those wanting to pre-meet out the front of Evolution R meet there at say 8:45am. This will be only a short quick meet-up and then we'll cruise to megamart.
sounds good! i will be meeting at the megamart... keep an eye out for a green soarer that looks like a moo cow thanks to that fantastic fibreglass patching up of the front hehe.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
