Wow ggs - I rang Steve Jarvin Nissan myself and they confirmed exactly what Revolution said. 198+gst
Thanks Scotty but I might stick with a new one. If original lasted 9 years - no point gambling on another similar age. I was already paranoid of the 2nd hand buckle that I replugged the wiring of the original(broken clip) & reset, as well as pulling out the seat and checking all the plugs.
I really think this issue is related to our bad roads- really bumpy, and maybe thats just worked the tension free a bit in my case through some high speed stuff that or a faulty one or both :)
Fair enough. Things will get very costly replacing all your broken/worn parts with new ones. Perhaps it's time to ditch the car for a current model, just because it's old now...
Gambling on S/H parts... Anyway, if you want new you don't pay Nissan retail, get on to Amayama.
All I have to do is get a job before I start dreaming of a new one & whilst I like them- they dont appeal like the v35...Im certainly not sentimental at all about replacing if/when more faults start cropping up. My R33 was about 10 years when little things started failing so guess this is getting there
  • 1 month later...
Mine started flashing on my way home from dinner tonight =(. Tried to reset it with the two methods above and it has now stopped flashing but still gives me a warning light when I turn on the ignition on but goes away after 10seconds or so. Will get it looked at in 500k's when it goes in for its 90,000km service.
Hi Lee, its exactly 7 seconds and hopefully it stays away for you too. When doing the resets you can actually hear the "clock". In the off position its every two seconds. I guess thats why you turn on after 4 on reset. Goodluck
Isn't it supposed to do that? mine always has.. the airbag light stays on after starting the car until it has comleted all system checks.
Yes but it stays on about 5-10 seconds longer then the other warning lights which it never used to before.
Still driving the car today and it hasn't started flashing again so seems to have done the trick (touch wood) but none the less I will get it checked next service which should be next month.
Sorry to hear. In my previous post . I actually typed "electrical things never go away until fixed".But deleted it because I didnt want to be the bearer of bad news so I deleted it..In my previous posts above you can see it did exactly the same.oh well at least you know for sure now.
  • Like 1
  • 2 months later...
Noooo just as I put my V35 on the market I get into my car this morning and the bloody airbag light starts flashing :(
Gold Coast Nissan don't touch imports apparently and I can't find other mechanics who have the system to clear the warning grrr
Sorry to hear it. Try the manual reset mentioned above that will clear it but most likely these things return.. Just an idea but maybe one of the compliers up their will have a scanner that can identify the problem if it returns.good luck
yeah was in a bit of a rush this morning when I tried to clear it using the steps mentioned and didn't work but just tried this afternoon and it cleared it by turning it on and off 4 times phew :cheers:
Now hopefully it wont come back before I sell it eek! Moving overseas and it has been an outstanding car since I've owned it and don't need the hassle of trying to get it fixed.
Edited by D2K77
SRS is very annoying when it has problems. Can be anything.
Take a read at
http://www.nicoclub.com/FSM/G35/Coupe/2003/srs.pdf
For my car the seat belts were tampered so the indicator kept coming back whenever I pull the belt hard - but as the article said, a flashing indicator can be anything, clock springs, sensors, modules, belts.
  • 2 months later...
My 03 coupe started to do this about 8 months ago. I don't recall what error code it was throwing up (something about a faulty sensor?) but my mechanic went through the whole system and couldn't find anything wrong. They also did the reset procedure and the light came back on after about a day.
I did the ECU reset procedure and it hasn't come back on since!
  • 10 months later...
I know this is an old thread, but I know some had mentioned they hadn't see the anti-submarine rams, I had my drivers seat out yesterday to fix and intermittant connector and thought I would take some pictures. It is fairly tucked up inside the seat, but you can see a bit of it.
All photos were taken with the seat lying on its back, so the top of the picture is the front edge of the seat.
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
