I'm finding I'm having to reset the Air bag light every 3-4 weeks. Is this usually a symptom of a faulty connector or something more serious? I presume if a module is faulty, it would throw a code straight away.
I somehow got the airbag light into a diagnostic mode and it flashed once and then ten times and repeats. I couldn't find any reference to this code anywhere. Anybody know what this code refers to?
Thanks
Get it on a Consult 3 unit, that way you can get a description of the fault. I think the seat switch contacts play up occasionally. These can be shorted I think, my aftermarket rails came with a plug in module, but it showed zero resistance when i measured across the pair of wires.
Does yours have 4 yellow wires in the plug under the seat, or only two? Some have an anti dive ram in the seat, some don't.
I couldn't clear mine manually using the procedure you used, my airbag light flashed for many years before I bought the consult3, that cleared it instantly and it has never come back.
  • 3 weeks later...
Purchased Nissan Datascan and an adaptor and read the codes. (works well with the 300GT)
Came up with a B1166 which I gather to be LH side (passenger) floor harness or seat belt pretensioner.
So what are the chances that its just a bad connector?
Thanks
  • 3 weeks later...
Ive had the flashing light for a week now. Did both man resets several times the most they last is a day. Took it Michael at Revolution electronics and he ran a scan. It detected a fault with the "clock spring" at the base or the main airbag. A new one costs $200 from Nissan and is on order.
I was curious if anyone else has experienced this? I cant see too many here that have it.I had issues with my drivers seat 4 months ago but the scan found nothing there ) maybe that triggered it. Michael says seat belt pretensioner/ clock springs are common with cars this age. Mines a late 05.
Mechanics are good at lines like that to stop you questioning them.. clock springs aren't a big issue in general for all cars. my J30 maxima was 18 years old when it died and it never had clock spring problems. and plenty of 10+ year old cars with seatbelt pre-tensioners that aren't having issues either.
I know the seat base harness is a common source of SRS faults on the V35.
Hi Scott- I saw the scanner code detected was the one for clock spring so I have to go with that. Mine is series 2- 11/2005. I dont know if you can rely on an airbag component being second hand ?.other than door looks been brilliant for the 7yrs I ve had it.Is it something anyone can install or safer bet to leave to expert?
Thanks
Well so much for that- plugged in my old seat belt buckle (broken clip) and did another manual reset and the Airbag light is gone..Now its in to Nissan & Nissan Only - now what are the chances of getting my $75 back for the scan...did i hear whistles..
Were you being sarcastic?. As I said it doesnt look like the clock spring after all- because plugging in my broken old buckle & doing a reset cleared the airbag warning light!.
Maybe its a temp thing but I will hold off & just replace my buckle from nissan $77.00
For the clock spring Nissan quoted $198 ex gst. Did someone take $100 to fit it
no i was charged 315 dollars from northside nissan for just the part , a mate fitted it , from my experience the clock spring is main issue for flashing light, once the spring is replaced youll have to do the reset process, if your steering wheel has been removed in the past ,then the spring would be high on my list of possible faults
I could do a clock spring from an 80,000k Stagea for $100. As I said, I have never had to replace one, and I have had my steering wheel off countless times, as well as customer cars in for cruise control installs etc.
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
    • Hi. a little later but if the topic is here. So...the exhaust is the same and you can use 25/Turbo or any aftermarket? What about intake side? Is it too "plug n play" or? (i do not remember for 100% but i think that one intake to head gasket was little bit different than on the RB25 - i bought gasket kit way back) I know that even if it "plug" those butterfly swirls would cause ECU to be confused or?   Just asking for the info 🙂 and of course the RB25 things are easier to come by
