S13 Rolling Shell, S13 Clear Taillights/indicators, S13 X Force Exhaust, Greddy Pro Spec Ii, S13 Power Fc, Gfb Bov, Kaixen H1 Hid, Spacers, Injectors
Hey Guy,
Cleaning out my garage: Mainly S13 parts however got a few bits and pieces that are generic
S13 front strut brace - $50
S13 Standard dump pipe - $40
S13 front Reo, been cut for fmic - $50
S13/14/15 rear braided brake lines, brand new- $50
S13 crystal front bar indicators, used but in great condition, comes with globes and plugs - $60
S13 clear tailights in mint condition - $140
S13 Power FC, to suit blacktop S13/180sx was tuned for z32, T28 and 55cc injectors, comes with handcontroller - $700
S15 hot pipe with blitz bov - $150
S15 OEM Injectors taken out of my Nissan AUS Spec S Manual S15 - $170
GFB stealth bov - $200
Greddy pro spec II - $250
Blitz FATT Turbo Timer - $50
S13 x force turbo back 3" exhaust with dump, cat, resonator and cannon muffler - $350
Kaixen HID KIT - H1 Globes, 6000K, no box, used for 6 months then sold the car - $100
52mm Vacuum gauge, used comes with box and all, lights up 7 colours or something
60mm Oil Pressure gauge, comes with hood, wiring and instructions
52mm Air Fuel gauge, used comes with wiring and all
All threes gauges for $70
15mm 4x114.3 spacers (pair), comes with bolts and all - $90
25mm 4x114.3 spacers (pair), comes with bolts and all - $90
SR20DET T28 braided turbo and water lines - $120
SR20DET T28 BB braided turbo and water lines - $120
Pick up from Glen Waverley
Cheers Phil
0433950285
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
    • Interesting. I've not dived into the cleanliness of the factory CAS. I'm curious if the variations are less of an issue if the OEM sensor were brand new. Optical sensors if they're starting to get dirt and crap into them as they're getting older would definitely cause issues as they age.   It's an interesting point to keep in the back of mind for me though
    • Hmm. Tough one. Without knowing where the conductivity value is supposed to sit, it's hard to know whether a standard DMM set to an available ohms setting would be able to measure anything. Ohms being the inverse of what we're talkng about and probably good enough for the girls I go out with. But if you want to go all hoity toity with a 4 wire rig - go ahead. It can only be more accurate - just in case more accuracy or repeatability turns out to be required. If you're going to the effort, just go chuck the ohm-mage probes into the car's reservoir and see if you can measure anything at all?
    • So, barely torque them, but add a drop of Loctite just to be sure?...
    • Was good fun with some old a school sau
