the guy at musecret said the br's are more for track and are stiffer
dunno if they have a heavier spring rate or what ?
but they would be harsher on daily driving
Are the ones at musecret br's ? thought they were the same v1 ?
this is getting confusing lol
Dude the BC BR's are not even remotely close to harsh. If you run 30 clicks maybe (never done it), but on three clicks it's just slightly stiffer than stock. I'd say about as typical as a standards "sports car"..
BRs have a bigger shock, which holds more oil, and is apparently better quality oil too.
I have BRs with the standard spring rate, and I think they're pretty good. Set to full soft, they're way too soft. I run mine about 5-10 clicks from hard.
BRs are supposed to 'be for track' because the larger oil volume means the oil doesn't heat up as quick (apparently), and they can take more of a beating.
I know Leon ordered his with a softer spring rate, about 1-2kg softer front and rear, and he's really happy with them.
I'm only two in from full soft front; three in from full soft rear.thumbsup.gif
No point turning it into a billycart; doesn't make 'em quicker around corners.whistling.gif
Damn so I'm the only one running them on one click. :unsure:
Looks like I'm even more keen on the comfort - full soft for me :thumbsup: . And as Ryan said, I ordered mine 2kg/mm softer as well. Loving the ride, especially since roads here aren't perfect.
Started with more clicks towards hard & worked back to soft. Can corner fast enough to get put in the big house, so why be uncomfortable while doing it?
  • 8 months later...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
