the guy at musecret said the br's are more for track and are stiffer
dunno if they have a heavier spring rate or what ?
but they would be harsher on daily driving
Are the ones at musecret br's ? thought they were the same v1 ?
this is getting confusing lol
Dude the BC BR's are not even remotely close to harsh. If you run 30 clicks maybe (never done it), but on three clicks it's just slightly stiffer than stock. I'd say about as typical as a standards "sports car"..
BRs have a bigger shock, which holds more oil, and is apparently better quality oil too.
I have BRs with the standard spring rate, and I think they're pretty good. Set to full soft, they're way too soft. I run mine about 5-10 clicks from hard.
BRs are supposed to 'be for track' because the larger oil volume means the oil doesn't heat up as quick (apparently), and they can take more of a beating.
I know Leon ordered his with a softer spring rate, about 1-2kg softer front and rear, and he's really happy with them.
I'm only two in from full soft front; three in from full soft rear.thumbsup.gif
No point turning it into a billycart; doesn't make 'em quicker around corners.whistling.gif
Damn so I'm the only one running them on one click. :unsure:
Looks like I'm even more keen on the comfort - full soft for me :thumbsup: . And as Ryan said, I ordered mine 2kg/mm softer as well. Loving the ride, especially since roads here aren't perfect.
Started with more clicks towards hard & worked back to soft. Can corner fast enough to get put in the big house, so why be uncomfortable while doing it?
  • 8 months later...
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
    • No. Go a different colour, and just trim it at an edge line. Even manufacturers do different panels different colours etc.
    • I see no real downsides to ITB's, apart from the initial cost of my drive in drive out lifestyle, the "upsides" is they sound cool and would add lots of smiles I am willing to pay to play for the extra smiles I've spent the morning googling and youtubing the BBR ITB's, a "little" extra power and throttle response, but alot more dort, and really, I'm only really in it for the dort Who knows, after all this money is spent I might even make 150kwatw....LOL
