hey guys,
just a quick question im proberly moving from ACT to WA in about 1.5 months as my dad is getting a transfer via his work, now what i am wondering is i have a rx7 with a fair bit of work done most notable being a surge tank and big fuel pump (both hidden under car, and also a high mount turbo with ext wastegate and screamer pipe exhaust will not be overly loud. im just curious as to how strict the modification laws are in WA and how hard it would be to get this car passed in this state.
we will be goin to northam area.
thanks guys
mark
https://www.sau.com.au/forums/topic/382013-moving-to-wa/
Mike is right if you can prove more than 12 months ownership it just get transfered over with out needing to be checked. We did this when we moved over with the wifes car by showing 3 rego forms in her name. If you cant then it will be a trip to the pits (have a search plenty of info) which will mean either returning it to stock OR putting in an application to approve the mods BEFORE going over. Most things get approved but a screamer WILL NOT so that will be the first thing you will have to change.
Edited by Boss-zilla
https://www.sau.com.au/forums/topic/382013-moving-to-wa/#findComment-6093901
Legally speaking the mods, especially the surge tank/high mount turbo will need to be approved by way of filling in a modification application form. WA can be quite strict on overly-modified turbo cars. The modification application form takes anywhere between 4-6 weeks to have the modifications either approved or denied. Sometimes you are required to gain engineers approval for modifications.
http://www.transport.wa.gov.au/mediaFiles/LBU_F_VS_ModificationLightVehicles.pdf
Just so you know, this is the legal way of registering your vehicle in WA with the listed modifications. A lot of the time when you go for an inspection to have your car registered, as long as the modifications are safe etc, then they should be fine.
The screamer pipe will be a no-no under all circumstances. You will not pass an inspection with that installed, and if the police pull you over and see it they will give you a defect compliance notice (yellow sticker).
As you will be in Northam, the place that conduct vehicle examinations in that area are what we refer to as Authorised Inspection Stations (private businesses that conduct vehicle inspections on behalf of Dept. of Transport in regional areas).
Just so you know, if the RX7 is registered in your name in the ACT and has been continuously registered in your name for more than 12months, and you can provide registration documents from the ACT to prove it has been in your name for more than 12 months, then you will NOT NEED AN INSPECTION to transfer the registration to WA plates.
If the RX7 has been in your name for more than 12months, then this will be your saving grace, as you won't need an inspection and this means you won't have to worry about being picked on due to the modifications on your car.
If you want more info, call 13 11 56 and ask to speak with me (Jason) and I'll give you the full run-down on how to transfer the registration over etc.
https://www.sau.com.au/forums/topic/382013-moving-to-wa/#findComment-6094331
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
