]WHITE R32 GTS-T
ALL PARTS FOR SALE IF NOT LISTED JUST ASK
FRONT STRUT BRACE $50
DRIVERSIDE GUARD $100
COMPLETE DOORS $100 EACH
WINDSCREEN $50
DOOR MIRRORS $50 EACH
TYPE M SPOLIER $50
REAR PODS $100
SEATS $150
DOOR TRIMS $25 EACH FEW MARKS
FRONT & REAR BRAKES $500
TAILIGHTS $50 EACH
REAR BAR $75
REO BAR $75
REAR REVERSE LIGHTS $50 EACH
TAILSHARFT $100
MANUAL PEDDALS $100
BARE SHELL REGO ABLE $600
R32 GTR GENUWINE 69,000K'S
PASSENGER SIDE GUARD $300
MOMO RACE WHEEL & BOSS $150
GTR WHEELS $800 NEW TYRES
GTR SPOILER $100 OR $150 WITH BOOT
TAIL LIGHTS $50 EACH
REAR REO BAR $100
IGNITION BARREL AND DOOR LOCKS $150
SEAT BELTS $25 EACH
RB26DETT APEXI POWER FC $1100 WITH HAND CONTROLLER
GTR GAUGES $100
NISMO GTR CLUSTER 320KPH $500
APEXI COIL OVERS $900
NISMO STRUT BRACE $150
APEXI PODS $200
REAR SWAY BAR $150 WITH ALL BRACKETS
COMPLETE REAR CRADLE
DIFF, DRIVE SHARFTS BRAKES $600
OIL COOLER & RELOCATOR $500 (NEEDS ONE FITTING)
FRONT BRAKES $300
HKS TOP INTERCOOLER PIPES $200
REAR GTR SEAT TOP IS FADED $125
BARE GTR SHELL AND CAN BE REGISTERED $1000
RB26DETT MOTOR AND LOOM $3000
IN THE ACCIDENT THE ALTERNATOR WAS SNAPPED OFF THE MOTOR
SO THERE IS A SMALL HOLE IN THE BLOCK
YOU HAVE TO WELD IT BACK ON WHICH WILL COST $100-$200
SEE PICTURES 69.000K'S ALSO NEEDS A WATER PUMP.
CALL/TXT LUKE 0431 391 262
TXT IS BEST ON WEEKDAYS AS IM ALWAYS ON THE PHONE AT WORK
WILL POST MOST PARTS AT BUYERS COST.
Edited by skyline_r33_panda
https://www.sau.com.au/forums/topic/382015-sa-wrecking-r32-gtr-and-gtst/
Hi,
after the following if in good comdition;
dash centre vents, window demist vents, clips that hold sill garnish, clips/screws for ecu and kick panels, internal door handles if in vgood condition, and cover over door handle bolt (on inside of door trim - passanger side) and the clips that hold the garnish down under the window wipers
Also after the plastic bits that sit inside the door and cover mirror bolts (triangle) and the metal plate that separates the rear seat to boot and boot trim
Probably a bit tricky posting some of that to Perth (wa) but what ever you have and willing to send over - please let me know
Cheers
Ps: also after the clock if it's working :)
Edited by Steve
  • 2 months later...
Hi if you still have the gtst i'm after the power steering line that goes from the pump, under the engine on the front of the crossmember then connects to the lower of the big banjo bolts of the front of the steering rack, it also has a sensor in the middle of it (I can provide pics if needed).
And would you be willing to post it to Wagga (2650) ?
Cheers
Vince
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 馃檪
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 馃 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 馃槉, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive 鉂わ笍 . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts 鉁岋笍
