For Sale of my old engine, done 6000 Klms parts are still in perfect condition. Im selling these cheap so dont hassle me on price.
ATI 1000 HP balancer for RB 26 with pulley ( the balancer has been drilled by the previous engine builder but is still perfect for someone) $250
Tomei Type A valve springs and SuperTech titanium retainers brand new $300
Complete set of second hand stainless Ferrea intake and exhaust valves perfect condition (std size) done 6000 klms $250
5 x CP std bore RB26 forged pistons, ceramic coated done 6000 klms still perfect $150
HKS purple fuel rail dual feed perfect condition with fittings and mounting bolts. $200
2 x Bosch 044 fuel pumps they are in perfect condition ( I have changed my fuel set up ) $200
GTR R34 V spec rear Brembo brakes and rotors ( 322mm N1 ) complete with 2 sets pads and brake lines perfect condition no scores. $1000
Xenon GTR R34 headlights L/R good condition not a scratch and lens are perfect. $1000
GTR R32/33 front drive shaft good condition $150
GTR R34 6 speed gear knob perfect condition $150
I have got other parts for GTR R34 as well.
Text me on 0412 950192 I leave Australia on the 9th November for 3 weeks so if you want them now let me know.. otherwise it will have to be when I get back.
Cheers Dave
Ok update on what has sold..
Pistons are gone..
ATI balancer is pending but first in with the cash gets it.
HID headlights... pending
I forgot to add the following for sale
Blitz NUR Spec stainless 3 " exhaust for GTR R34 good condition has a slight dent on the bottom of the Cat otherwise perfect $400 plus shipping ( Exh in Brisbane)
6 x Siemens 900cc injectors 11mm Perfect condition bolt straight onto a RB26 ( as used by Mark Berry in the hi octane car) come with flow chart if you want it. $400 plus freight ( they are in Bris)
Edited by SkylineSky
ATI balancer is for a GTR R34,
Injectors are straight swap for genuine one so just a push in with the standard fuel rail. I do have a HKS rail if you need that as well.
Blitz exhaust is for a GTR R34
V spec Brembo brakes will fit any GTR model..
Cheers Dave
Update on what has been sold and what is left.....
5 x CP std bore RB26 forged pistons, ceramic coated done 6000 klms still perfect $150 Sold
Xenon GTR R34 headlights L/R good condition not a scratch and lens are perfect. $1000 Sold
Blits NUR stainless 3" exhaust for GTR R34 $400
Siemens 900cc injectors Sold
Cheers Dave
Cheers Dave
How much use have the pumps had?
They have been in the car for 4 months and the car has done 800 klms in that time.... they are working perfectly.
Im away for the next 3 weeks O/seas so anyone wanting any of the parts will have to wait.
Cheers Dave
Cheers Dave
Cheers Dave
Cheers Dave
Bump, there are a lot of low ballers wasting my time who don't have the money if you you are dreaming about these parts you will be very politely told to F.O.
The price is there for everyone to see.
Thank you.
"Jesus H Christ" cant people read my post...... the Brembo brakes are REAR brakes only........off my V spec and I dont give two hoots if you cant afford them....
Maybe a english lesson will go well on this forum..
  • 3 weeks later...
These parts are still for sale due to Low ballers who don't have the money...
ATI 1000 HP balancer for RB 26 with pulley ( the balancer has been drilled by the previous engine builder but is still perfect for someone) $250 plus shipping
HKS purple fuel rail dual feed perfect condition with fittings and mounting bolts. SOLD
GTR R34 V spec REAR Brembo brakes and rotors ( 322mm N1 ) complete with 2 sets pads and brake lines perfect condition no scores and GTR R34 front rotors (no calipers). $1600 plus postage
Xenon GTR R34 headlights L/R good condition not a scratch and lens are perfect. $1000 plus postage
Siemens 900cc injectors perfect condition bolt straight onto std fuel rail using std connectors. $450
Cheers Dave
There are a lot of low ballers wasting my time who don't have the money if you you are dreaming about these parts you will be very politely told to F.O.
Thank you.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
