For Sale of my old engine, done 6000 Klms parts are still in perfect condition. Im selling these cheap so dont hassle me on price.
ATI 1000 HP balancer for RB 26 with pulley ( the balancer has been drilled by the previous engine builder but is still perfect for someone) $250
Tomei Type A valve springs and SuperTech titanium retainers brand new $300
Complete set of second hand stainless Ferrea intake and exhaust valves perfect condition (std size) done 6000 klms $250
5 x CP std bore RB26 forged pistons, ceramic coated done 6000 klms still perfect $150
HKS purple fuel rail dual feed perfect condition with fittings and mounting bolts. $200
2 x Bosch 044 fuel pumps they are in perfect condition ( I have changed my fuel set up ) $200
GTR R34 V spec rear Brembo brakes and rotors ( 322mm N1 ) complete with 2 sets pads and brake lines perfect condition no scores. $1000
Xenon GTR R34 headlights L/R good condition not a scratch and lens are perfect. $1000
GTR R32/33 front drive shaft good condition $150
GTR R34 6 speed gear knob perfect condition $150
I have got other parts for GTR R34 as well.
Text me on 0412 950192 I leave Australia on the 9th November for 3 weeks so if you want them now let me know.. otherwise it will have to be when I get back.
Cheers Dave
Ok update on what has sold..
Pistons are gone..
ATI balancer is pending but first in with the cash gets it.
HID headlights... pending
I forgot to add the following for sale
Blitz NUR Spec stainless 3 " exhaust for GTR R34 good condition has a slight dent on the bottom of the Cat otherwise perfect $400 plus shipping ( Exh in Brisbane)
6 x Siemens 900cc injectors 11mm Perfect condition bolt straight onto a RB26 ( as used by Mark Berry in the hi octane car) come with flow chart if you want it. $400 plus freight ( they are in Bris)
Edited by SkylineSky
ATI balancer is for a GTR R34,
Injectors are straight swap for genuine one so just a push in with the standard fuel rail. I do have a HKS rail if you need that as well.
Blitz exhaust is for a GTR R34
V spec Brembo brakes will fit any GTR model..
Cheers Dave
Update on what has been sold and what is left.....
5 x CP std bore RB26 forged pistons, ceramic coated done 6000 klms still perfect $150 Sold
Xenon GTR R34 headlights L/R good condition not a scratch and lens are perfect. $1000 Sold
Blits NUR stainless 3" exhaust for GTR R34 $400
Siemens 900cc injectors Sold
Cheers Dave
Cheers Dave
How much use have the pumps had?
They have been in the car for 4 months and the car has done 800 klms in that time.... they are working perfectly.
Im away for the next 3 weeks O/seas so anyone wanting any of the parts will have to wait.
Cheers Dave
Cheers Dave
Cheers Dave
Cheers Dave
Bump, there are a lot of low ballers wasting my time who don't have the money if you you are dreaming about these parts you will be very politely told to F.O.
The price is there for everyone to see.
Thank you.
"Jesus H Christ" cant people read my post...... the Brembo brakes are REAR brakes only........off my V spec and I dont give two hoots if you cant afford them....
Maybe a english lesson will go well on this forum..
  • 3 weeks later...
These parts are still for sale due to Low ballers who don't have the money...
ATI 1000 HP balancer for RB 26 with pulley ( the balancer has been drilled by the previous engine builder but is still perfect for someone) $250 plus shipping
HKS purple fuel rail dual feed perfect condition with fittings and mounting bolts. SOLD
GTR R34 V spec REAR Brembo brakes and rotors ( 322mm N1 ) complete with 2 sets pads and brake lines perfect condition no scores and GTR R34 front rotors (no calipers). $1600 plus postage
Xenon GTR R34 headlights L/R good condition not a scratch and lens are perfect. $1000 plus postage
Siemens 900cc injectors perfect condition bolt straight onto std fuel rail using std connectors. $450
Cheers Dave
There are a lot of low ballers wasting my time who don't have the money if you you are dreaming about these parts you will be very politely told to F.O.
Thank you.
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
