so i had my car at the mechanics the other day for a radiator water pump and turbo gasket change he also cleaned the plugs regapped them removed the manifold filed it to... its all back together now and when boost comes on my car gets no power at all the turbo sounds like its working but nothing is happening is it possible he has put it back on wrong its a high mount externally gated gt35/40 any ideas would be great guys use always help :)
https://www.sau.com.au/forums/topic/382073-turbo-boosting-but-giving-now-power/
I doubt you'll get anywhere near full boost if you had a boost leak, I'd say it would be more along the lines of a timming issue, either ignition timing or cam timing.
You said he changed the water pump, so the timing belt most probably was removed, it's possible one of the cams is out a tooth?
Also check you base timing, if it's retarded the car will feel sluggish. It's possible as the CAS would have been removed to get at the water pump.
Is also check inside the piping.
Mechanics put rags in them so no foreign contaminants get in.
Sometimes they forget to take them out.
Will have boost, with no flow.
As mentioned check the timing belt and cas.
Good luck with it.
  • 4 weeks later...
If you did the belt and that when it started chances are very high that either the belt is out by a tooth or 2 or your base timing isnt set to 15 get the light on it and check it out.
Put it all back together and still has the same problem WTF!!
borrowed a timing light and its out -30 degree ish.. advanced the CAS as far as i can go will put timing to 0 when timing should be 15.
time to pull it down again and check for the 10th time... and try and find where im missing 15degree still.
Could my CAS be rooted??? or maybe i have cam timing right but got the crank a tooth or two out? i got the belt right in the past but this time is doing my head in.
Where are you taking the timing from, the loop at the back of the engine or coil #1?
And what timing light is it (cheap, decent etc)?
Loop at back of engine and timing light is from Snap-on.
Car ran like shit again as i was just aligning the CAS back to the same marks before hand so i borrowed the timing light and when i checked it was so far off it wasn't funny.
Once i advanced the CAS the power was back but now top end power has gone completely..
I have checked compression and all cyl are over 160psi so that gave me some hope its not bent vales ect.
Is it possible for the CAS not to alight correctly even with the key?
I counted that i need 38 teeth between inlet and exhaust cam (or 39 to be one past) to line up the belt but with the crank i didn't count teeth i just slipped it on making sure the exhaust side didn't have any slack.. tonight im going to make sure i have the right number of teeth between exhaust and crank.. which is 47 if i read it correctly.
Always always check again and again when doing the belt before you tension it, after you tension it, then give it a few more rotation and check again so you know its right. It helps using a mirror when trying to see if the crank mark is lined up as its sometimes hard to see exactly. Use the marks on the belt to line them all up then count again to make sure but yeah it is possible for a faulty cas to retard it like that so that can be next checklist once your 100percent sure the belt is lined up.
yeah i have checked and checked again might even try and take a photo and upload it as i could think its aligned but i actually have it off..
Timing belt does not have any marks except for 3 lines all together (its a gates racing belt) and this is why i am counting the teeth (i think I should be counting the gaps on the belt as the numbers are actually on the cam and crank pulley teeth)
Fingers crossed i have it all right and its possibly a f**ked CAS as ill be changing it if i have it all correct.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
