Hey everyone my battery light came on last night in my R34 while I was driving around town and I got to see it for a few seconds before all of a sudden my revs just died out and my car died, then immediately came back to life. The light would then intermittently turn on and off and the car died once or twice more then it stopped, and for about an hour nothing happened, it just drove normal. After this hour it happened again when I was just about home so I parked up and have left it alone today.
I tested the alternator this morning and it was charging at 13.8v and I checked my battery and that was holding 13.8v also while the car was running. Does anyone have any ideas of what this could be?
Mods:
RB25/30
ViPEC
Plazmaman Plenum
3076 on a 6boost Highmount
50mm Turbosmart Wastegate
Sard Injectors
Intank 044
Battery Mounted in boot (I checked the earths and connections on this and they looked good)
Any help will be appreciated.
Thanks
Also check your charge rate with your high beams, a/c fan, and brake lights on.
Need to see what the charge is doing under load.
Could still be a faulty alternator, possibly voltage reg on its way out.
But as mentioned, check your battery terminals, and earth points first.
Then go from there.
Good luck.
Sounds like the alternator or volt reg.
Really need a dc clamp meter to test it properly. Volt meters are handy but can give rricky/false readings.
if it was the alternator or reg the engine wouldnt die immediately as it still has the battery to run off. ecm would prob switch off between 8-10 so there would be ample time
sounds like something loose or even a short in batt cables
Hey guys, checked all those things and everything seems fine. The light came back on yesterday and so I tested the alternator and it was only charging at 11v. So I'm going to get it replaced as it seems to be an intermittent problem with that.
check the belt tension aswell? could be slipping
Once more, intermittant alternator wouldn't cause the engine to cut out like the OP describes... It would continue to run just fine off the battery for many more km's until the battery voltage drops to something crazy low like 8v or whatever the ECU starts getting confused at.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
