Ok guys i've done a bit of searching but can't really find much info.
I'm extending the sump on my GTR and want to know if there would be much benefit in having cooling fins on the sump?
Would there be much air flow down there?
I realise that the oil is moving around alot but surely if you can get the sump a bit cooler it will take a few degrees out of the oil.
Thoughts anyone
https://www.sau.com.au/forums/topic/382088-cooling-fins-on-sump/
As long as it doesn't sit too close to the road, I don't think it can hurt....
How about a before and after comparison, then we can all know...
I've often thought of this with the gearbox as well, pretty sure you can buy the stuff like heat shielding, but it helps cooling.
An acl product if I'm not mistaken.
If you give it a go, please share your results.
Good luck.
An example in the right direction is the old ALFA engines from the 105 and 116 chassis. They had big cast aluminium sumps and the outside of the sumps were completely finned. So you had the combination of a better material for heat conduction (aluminium), plus a better surface finish for convective heat dissipation (as cast rather than painted smooth steel) and fins on top of that.
On that basis it would be easy to argue that you couldn't possibly provide too much heat dissipation off a sump.
To achieve anything really useful though, you'd want to be welding on 6-8mm deep fins every 6-8mm I'd suppose. And it would end up looking bloody ugly.
There is talk though that for cars that are road driven it can be hard to warm up a large sump full of oil as it is. If the car is hard thrashed every time it is driven then this isn't a concern, but even a dual purpose track/street car might suffer from low oil temperatures if you make it too hard to warm the oil up. A thermostatically controlled cooler would be smarter in that case.
Even then with a thermo, mine with 9.5ltrs takes a solid 10mins (5mins before seeing boost and then more heat) to warm up before the gauge even moves off it's pin.
Generally tyres/brakes run out before the oil cries enough as well with that much oil in there.
Some good info there GTSboy, i was thinking it would be getting a bit messy with all that welding. So i was thinking about milling some slots in 12mm flat bar.
I didn't really think about it being too cool, i guess if i did it i could cover up or bypass the cooler for the street and drags and then use the cooler on the track.
So nismoid how long on the track are you driving for without having the oil get too hot?
I'm not to worried about warm up time as the car is not driven daily.
Ok the car is fine now, doesn't get hot as it's only got basic upgrades. i'm mounting the oil cooler now with proper ducting.
I'm about to do the sump extension now for my new engine so while i'm at it i thought i would ask what people think of it, cause now
is the time to do it.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
