hey all,
im new to the forum and im half looking at getting my first import and out of the commodore.
need some advice ont what to get, im considering everything from silvias and skylines, to soarers for some luxury. i dont need a car stupidly fast but i want some creature comforts aswell.
what would be suitable and within a reasonable price range?
https://www.sau.com.au/forums/topic/382089-advice-on-first-import/
  • Replies 72
there are wide selection depend on what you want. may be answer the following questions will help?
what is your budget?
How old is the vehicle that you willing to try?
RWD/FWD/4WD
leather seat?
Turbo or supercharge or V8
2 or 4 doors
Does the aftermarket support important to you or happy to go for custom jobs
what is the KWs you try to get out of engine
Well im looking up to 10k for now i guess. And i know about the KPGC10's being mega dollars these days. I'd prefer a manual coupe of some sort anything back to 1990ish, and i'd want one fairly stock so i can mod it myself, its a better feeling than getting a ready made machine. My mate has a 32 gtst manual which i helped him work on and i love driving it around when i can, and another friend has an 01 wrx which handles on rails. Maybe a 32 GTS4 because i like the shape and AWD grip feels awesome
haha the rb20 cops so much flack, i like it, kind of an underdog. im not looking for too much power right now anyway. that 33 v spec link looks like a scam too, 10k for a very low k's gtr with mods is way too cheap.
My opinion:
10 grand will get you a skyline I think however it won't get you into a soarer that is worth loving.
10 grand will easilly get you a series one twin turbo but of you're chasing a series 3 elec seat update interior update engine update body type then 10k won't be enough,
Same will go for skylines,
Like 91 models etc fine... But you won't get a 99 skyline or a 99 soarer with that budget...
Reason I say this is, you're new to imports, you haven't yet got the connects or the parts Hookups or the work arounds if things go wrong.
And so for your first import car you will want it to be a good experience not a bitter one, best wAy to get a good experience is buy right the first time,
Increase your budget slightly and you will save the money on repairs in the long run.
Not to mention picking up a less tired interior and newer seats etc
I know you're probably looking into "punk" kaido imports like skyline soarer Silvia etc,
But also don't be afraid to look into Lexus IS200 aka Toyota Altezza, they're ridiculously cheap now and with a nice detail (done by me) can really look the part with some nice wheels :)
Happy hunting !!
As a former Soarer owner I would say they are a lot of car for the money. Manuals still command a premium but even they can be had for around the 10k range now.
Not quite as good a handler as a Skyline but they are very easy to upgrade for straight line speed.
As a former Soarer owner I would say they are a lot of car for the money. Manuals still command a premium but even they can be had for around the 10k range now. <BR>Not quite as good a handler as a Skyline but they are very easy to upgrade for straight line speed.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
