Hey everyone I just had my car tuned by jez and he did a great job. The car made 224kw on a very safe tune I need to do a few things first before advancing timing and adding boost. We had a few problems from the start and took a while to fix. My little 20 seen 25 psi off a boost spike but man it loved it that was my fault tho . Had injector problems as well but jez nutted it all out. For such little boost it pulls mega hard cans wait for more power. I highly Reconmend jez as I tuner plus he is a top bloke. plus he found how to stop stalling without a bov plumb back but this his secret
Mods to car are
Kando dynamics td06h-20g
Gtr front mount
injectors mow sure on size now after tune
Decat with rsr cat back
Screamer reason for safe tune getting plumbed in soon
Pod with z32 afm
walbro 650hp pump
Stock fpr
Stock coils
Plugs at .8
Thanks jez and boydy for not giving up on me
https://www.sau.com.au/forums/topic/382116-rb20-dvs-jez-td06h-20g-winner/
Ur little RB20 loved 1.8 bar of boost. The thing made 180kw at 5000rpm before we backed off.
I am loving the kando turbo. Full boost at 4500 on a stock RB20 is unreal.
Stoked we found how to stop the stalling issue's without a BOV. Need to do some more testing yet but looks promising with the NIStune.
Hurry up and fix the few little issue's and we can finish the tune off with 18psi.
I'm hoping around 260kw but we will see what happens. Yeah I'm very happy with how the wastegate turned out looks great easy to access which helped last night because we had to remove the 10 pound spring as it was set to 17 pound which ended up being 22 . It's a very cost effective way to controll boost and easy access! I'm using a 7 pound spring and a 22 dollar mbc and I'm getting no spikes stays at flat 14. And make sure if your using gate pressure it's hooked up to the bottom port as we seen 1.8 bar from top port
Yeah mate eBay special I have a 8cm housing perfectly suites the baby 20. Luvpis look in the fab section and there is a step by step guide on how to has all photos on the job plus current setup. Can't be bothered to do it right now maybe later
+1 for Jez, one day the poor guy will get a car on the rollers that dosent need hours of stuffing around before he can tune it ;)
Boydy is a nice bloke as well hey. I was in a similar situation with my 33 and the guys just would not give up, a lot of tuners would just send you packing and tell you to come back when all the problems are fixed.
Nice result mate.
We went till 12:45am Dave. But then we had to send him to fix it up. His screamer was basically aimed at me so was too loud and couldnt hear what i needed to hear.
Finish it off this week hopefully.
Might have to change my name to midnight tuning
Roy what else is done to that 32 with TD06?
Its an absolute stock RB20. On that dyno run it had a HKS Type S Cooler, HKS Hyper Exhaust, HKS Air Filter, GTR Injectors, Power Fc/Z32 and it was a 98 track tune. Runs cam gears tweaked to get it on as soon possible. The 20 loves the 100 pump but sadly they pulled it from the bowsers here in Vic so have to make tune with the more conservative 98 tune
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
