You can pick up a half cut r33 for about 5k or less
Not really worth it, you can get an rb25 and box for 2-2.4k...
What ECU are you running? Chances are you will need a new one if you go rb25..
If you can do all the work yourself I'd be saying at least 3k total for a stock setup... but like I said then u need to look at new ECU/injectors .
I have kmon ears. But i prefer to have my head over the engine. I know its risky but i havent mastered the kmon to my liking yet.
I have never missed a ping yet. Just that some people want to push limits (BSA).
Nice kmon is killer.
if you can hear it in engine bay your already 3 degrees to far ie is already been suffering light to moderate det for those 3 odd degrees. I think i have a kmon setup thread somewhere with khz settings etc...
Once you get used to the kmon you will love it, im using knockbox atm but the beauty of the kmon is the logging software.
Is that the same knockbox as I posted above?
How do you find it?
I'm assuming you use the pro version? Any experience with the basic one?
For $400 I'm going to get myself one I think...providing they are decent enough for basic road tuning on a street car
I have the analog outputs from the Kmon fed back into the dyno data acquisition it's awesome, can have knock plotted over anything, boost, afr ect. Can also setup alarms in the dyno software for high levels ect.
Am also using STATUS frequency settings. They're mint!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
