May not be relevant but cam gears made a hell of a difference on my 25.
2835pro s all in (18psi) by 3200rpm, but I have a ff plenum etc and with the new huffer have inherited a bit of compressor surge which Jez will be working on for me in a couple of weeks.
Ok so went on the dyno last night made 242kw with major wheel spin from 5 grand on so can't get a proper reading had a extra 100kg in the boot and still spinning. There is a restriction somewhere holding it back as well will be playing today im thinking wastegate pipe so is jez so more fab needed will be opening it up to 40mm id pipe and further down the exhaust. Setup is stock rb20 with td06h running 18 pound and your usual breathing mods seeing full boost (on the road) 1st 4800 2nd 4700 3rd 4500 4th 4300 there abouts anyway didn't bother with 5th that's with mbc removed running gate pressure 10 pound spring. Now going to get a ebc and hope it rids my lag issues with a contoller. Any suggestions on why a mbc would be causing lag and please no dick answers.
Yeah wanted to find the issue and that was it. When it was connected wasn't seeing any boost untill 5800 so I though something is seriously wrong was worried I broke something. Also forgot to mention I lost around 30kw by plumbing in the external gate. As we did a power run before touching anything is that normal?
This is the least of my worries just pulled the intake manifold off for suspected blown gasket only to find a half empty radiator and milky brown water next up is comp test and a punch in the face by myself soon. My day just got shit I think
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
